I have a question, I did the floor moulding inside the closet this weekend, I choose closet to start first because want to see how difficult/easy it is as this is my first time also...
I found this is not as easy as I thought... in fact, may be difficult for a perfect cut... so I would like to know if you can provide me any tricks/tips on doing a perfect length/angle cut for this stuff, I want to better prepare when doing the actual area...
I discover there are inner/outside corner which is not 90 degree, so in theory, assume 45 degree cut is not correct... so what should it be done easiest and most accurate... do I need to measure every corner before cutting... also what is the best tool for this cut... I have now both table saw and chop saw... I immagine chop saw is easiest.... I used table saw for the closet find it difficult to find the point of cut, adjusting angle is ok... but cutting the right line is a bit hard....
anyhow, waiting to hear from you ... thank you...
never mind, I found a web site...
