Best Way To Dispose Of Grout Waste Water? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-17-2012, 10:28 AM   #1
Rewards Points: 682
Best way to dispose of grout waste water?
I recently saw some workers dispose of waste water used to clean up grout on a grass lawn. I've been wondering if you dispose of that water down the drains will the grout waste build up in traps and such? Or cause other problems?
darsunt is offline   Reply With Quote
Old 02-17-2012, 11:33 AM   #2
Rewards Points: 13,450
SHould be fine.
Old 02-17-2012, 12:38 PM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
My understanding is large gobs of grout can harden in drains. If you're talking about just dirty water that was used for the final grout clean-up you'd probably be fine, but why take a chance. I don't like dumping any potential problems down the drain.
I'm no expert, but I've always dumped any grout water outside.
Old 02-17-2012, 06:38 PM   #4
Rewards Points: 774
I'm with you. Why take the chance if you can dump it outside?
cibula11 is offline   Reply With Quote
Old 02-17-2012, 07:27 PM   #5
Rewards Points: 682
Where to dump it?
Your not supposed to dump it in the street drains (but I do if I can get away with it)
The grass where the waste grout water was dumped looks fine. Should you dump it on the lawn?
Old 02-17-2012, 07:51 PM   #6
Not going to harm the lawn.
Old 02-17-2012, 07:59 PM   #7
DIY staff
Rewards Points: 7,174
Not going to hurt the grass-----never dump any grout slush down any drain---ever--
what else would you do with the wash water?
Old 02-17-2012, 08:06 PM   #8
concretemasonry's Avatar
Rewards Points: 2,594
There is a common phrase that says "dilution is the solution to pollution" if it is controlled and it is used in many sewerage/water treatment plants. The key items are the reduction of solids(clods or clogs) that impair drainage and treatment efficiency if it flows to a treatment system or plant (usually an old combined storm/sanitary system). That is a big and very costly item.
There are situations where alkaline (lime based) discharges can be beneficial to sewerage treatment plants and may not be objectionable in storm water systems and the addition of lime to lawns is permitted.
Dick
concretemasonry is online now   Reply With Quote
Old 02-23-2012, 01:20 PM   #9
robertBny's Avatar
I agree with most posts here. Never dump the grout water down the drain because that water contains grout in it and could harden in the drain and cause a major headache.
I've done quite a few tile jobs and I usually just find a spot in the backyard, usually behind a shed or something to that nature to dump my grout water. It doesn't harm vegetation however I don't like just dumping it right in front of where my customer can see it in plain sight. From experience though after the first good rainfall any residue is mostly washed away.
robertBny is offline   Reply With Quote
Old 02-23-2012, 03:53 PM   #10
Mold!! Let's kill it!
Rewards Points: 2,012
I once saw a tile contractor made responsible to replumb the waste lines in a commercial building when his crew washed grout and tile tools off in the sinks. When the plumber cut the drain lines apart, they were 3/4 full of hardened grout. The owner wouldn't accept a patch, so they had to take the lines apart the whole way back until there was no evidence of blockage.............. A different tile crew finished that job.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
oh'mike (02-23-2012)
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Grout question poolecw Flooring 11 10-29-2008 07:32 PM
