Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-17-2011, 10:27 AM   #1
Best practice when capping vinyl windows in brick
We just had vinyl windows installed (retrofit) and the capping job is sub-par. I'm wondering what standard practice is so that I can go back to the installer with the correct demands if necessary.
Firstly, the windows are capped, but the capping isn't caulked to the concrete/brick - The pictures are basement windows, but it's the same for the brick edges on the 2nd story windows we had done. I'm assuming that the edges and bottom should be caulked to stop water intrusion, right? Or is this left for drainage?
Secondly, here's their capping job of sill. Should I demand it torn out and redone? I could probably do a better job myself given a weekend.
Any other work critique appreciated, I want these guys to do it right or it's straight to homestars with these pics.
And sorry about the sepia, I'm camera-challenged!
rugby style is offline   Reply With Quote
Old 01-18-2011, 02:10 PM   #2
I would qualify this as a mediocre job at best. Done by someone who doesn't have a lot of experience using a brake. Old houses can be a challange due to the trim installed, the multiple sidings and built up roofing. This guy was not up to the challange.
I'd have him redo it or get another guy to finish the job.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Tom Struble (01-18-2011)
Old 01-18-2011, 02:13 PM   #3
Tom Struble's Avatar
yea...that's a little rough,i will sometimes use that 1/2'' ''kick'' onto the masonry but i would set it into a heavy caulk bead
Tom Struble is offline   Reply With Quote
How to cut vinyl lineals for windows luvdairish Building & Construction 9 08-29-2010 06:19 PM
Installing new vinyl windows w/ foam&siding Macra Remodeling 3 08-27-2010 08:08 AM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 07:39 PM
Cutting brick to install windows (lentals?) buckwillis Building & Construction 6 08-21-2006 09:13 PM
