Best Foam For Basement Walls? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-14-2008, 06:15 PM   #1
Best Foam for Basement Walls?
I am just starting to remodel my basement. The house is 60 years old, but I have not had any water problems in the 2 years I have been here, except one time when the gutters were clogged.
The plan is to Drylock the cinder walls, then put 3/4" thick foam on the walls, then frame out the walls, electrical, then drywall.
I am about to buy foam, but cant find a good explanation of what's best. Home Depot and Lowes both have three kinds:
1: Pink Owens Corning Formular, R4
2: Blue Dow Super Tuff-R, R5
3: White 'High School Science Project' foam, R3
Anyone here have experience with these or know of any pros/cons?
thanks
heybrady is offline   Reply With Quote
Old 03-15-2008, 02:05 PM   #2
Jack of Some Trades
Wood Butcher's Avatar
it sounds like the biggest driving factor for you is the R value you need.
I am actually suprised that they carry three brands, each with a different R value. makes no sense to me
Wood Butcher is offline   Reply With Quote
Old 03-26-2008, 08:01 AM   #3
I would suggest the OC Foamular or the Dow board...these will offer better mold/moisture protection. I personally used 1" thick tounge and groove XPS (pink stuff from Owens)...found it to be cheaper than the Dow board. I used PL300 to adhere to my walls and framed 2x4 walls on top of that. I have not decided if I will put fg insulation in the stud bays yet or not.
chpwaman is offline   Reply With Quote
Old 03-28-2008, 03:06 PM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
Use an extruded polystyrene. Pink or blue, not much difference. Stay away from expanded polystyrenes like the beaded science fair or beer cooler stuff. They tend to absorb moisture over time.
Old 08-12-2008, 12:52 PM   #5
After reading all the posts on this board I can find about building exterior walls in basements, this is what I am planning:
1. Adhere foam board to the concrete using construction adhesive.
2. Build stud wall
3. Drywall over the stud wall
3 questions I have are:
1. Should the studs go right up against the foam or should there be a gap?
2. Is fiberglass insulation between the studs required?
3. Is there a risk of condensation building up between the foam and concrete running down to the floor and feeding on the bottom plate boards?
I am in southern Wisconsin and would prefer minimal insulation as the basement stays cooler in the summer and warmer in the winter right now with no insulation.
Thanks in advance!
simon is offline   Reply With Quote
Old 08-19-2008, 10:31 AM   #6
ttt, any comments?
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
Straightening Racked Walls smitty286 Building & Construction 3 03-11-2008 08:35 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 02:50 PM
wall sheathing, foam board, insulation and house wrap dr.demento Building & Construction 10 10-18-2007 04:42 PM
