Best (easiest) Way To Fur Out A Wall Only 1/2"? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-05-2012, 03:02 PM   #1
Best (easiest) way to fur out a wall only 1/2"?
I need to fur out a plumbing wall by just 1/2" to meet the rough in guide for a shower valve. Over this will go 1/2" cement board and glass mosaic tile (and moisture barrier). Any suggestions? Thank you.
Testarossa214 is offline   Reply With Quote
Old 01-05-2012, 03:05 PM   #2
Rewards Points: 12,830
1/2" strips of CDX would be the cheapest way.
Testarossa214 (01-05-2012)
Old 01-05-2012, 03:43 PM   #3
DIY staff
Rewards Points: 7,174
Are you sure about that? Is the offending wall 2x4 or something shallower?
Old 01-05-2012, 03:46 PM   #4
firehawkmph's Avatar
Rewards Points: 1,800
Just curious,
how is the extra 1/2" going to affect the front lip of the tub? Losing a half inch only on one side may look strange. Can't you move the valve body back?
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-05-2012, 03:49 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
All shower valves allow for some "play" when installing them. I have never heard of a "have-too" fir-out a 1/2" for shower valve placement.
XXX
Old 01-05-2012, 04:48 PM   #6
The existing wall is a 2x3 wall, unfortunately. I was hopeful that as we were just replacing the valve with a new one in the same wall that the plumber would be able to work with it. But that apparently wasn't possible with the fixture we chose. The tub, also, has a small gap (approx 1/8"-3/16") between it and the framing at this side that needs to be tightened up.
The current gap between the plumbing spacer and the existing framed wall is 1-1/4". So, my plan is to put 1/2" furring over the studs, plastic sheet over that lapped over the tub lip (I'm paranoid from a couple years of a leak down into our kitchen below), 1/2"cement board over that, moisture barrier, thinset and tile.
It would have been easier to reframe that wall, i know. Hindsight is 20-20. I have a trim detail in mind to hide the front edge, where it could look strange.
Old 01-06-2012, 11:59 AM   #7
What's on the backside of your wall where the shower valve is going? Closet by chance? If it were, I would make amends for it to stick in a little there and just make a nice cover for it. Just seems like when you do something to make do, it usually comes back to bite you when it's too late.
Mike Hawkins
The Following User Says Thank You to firehawkmph For This Useful Post:
mae-ling (01-07-2012)
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Slip-on diverter with less than an inch of 1/2" copper nipple out of the wall jamesm113 Plumbing 3 07-24-2009 12:23 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
