Bedroom Recessed Lighting Advice Wanted - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-27-2011, 02:06 AM   #1
bedroom recessed lighting advice wanted
doing a few remodels in the bedroom and one of them that i was wanting to do was to install recessed lighting in my bedroom to clean up the appearance and have a little more lighting in the room as far as even light all around. the room is roughly 11ft deep by 16ft wide. door is at the southwest corner on the south face (if drawing a box in your head). the ceiling is around 8ft tall.
i am figuring from the research ive been doing online is that it would be 2-3ft away from each wall. my thought was to go with (4) 6 inch remodel recessed cans and go with LED light fixtures sooner or later with a wide flood pattern. LED for power and less heat and dimmable (plus slight neat factor). would i be pulling too much power or putting out too much light with the 6 inch cans or would i be smarter to go with (4) 4 inch cans (my fear is not enough adequate lighting). these lights will not be used for reading but for general room illumination.
as it sits right now its a center ceiling fan with a 4 bulb light kit attached to it in a + formation. the switches in the room, it is a 3 switch panel, one for the light kit, one for the fan itself, and one for a wall socket on the west wall of the room.
and do you recommend any mfgr's for the remodel cans, so far i found on home depot the Halo H7RICT 6 inch cans, and with the promo code from retail me not, it would be $45 with tax for 4 of them.
andrewbp is offline   Reply With Quote
Old 09-27-2011, 06:55 AM   #2
Rewards Points: 156
Look at usalight.com I use 5" cans almost exclusively. Much cheaper than hd
ryan5068 is offline   Reply With Quote
Old 09-30-2011, 10:11 AM   #3
Rewards Points: 5,336
You should be fine, power wise, if you're using 4 lights. Four leds use much less power then incandescents.
Ron
B. Franklin 1759
Cover for Recessed Lighting Trim Model HBR635(T49) aghahary Electrical 4 07-23-2010 05:30 PM
Recessed Lighting Placement monkeystomach Electrical 6 03-10-2010 08:29 PM
Recessed lighting for 15 amp circuit jacads Electrical 5 03-12-2009 01:12 PM
Insulating IC recessed lighting. topher0524 General DIY Discussions 4 02-10-2009 07:03 AM
Recessed lighting in billiard room? kcrossley2 Electrical 11 01-11-2009 09:00 AM
