Bedroom Basement Window - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-18-2010, 11:27 PM   #1
bedroom basement window
what size does it have to be to meet code?
rigas is offline   Reply With Quote
Old 05-19-2010, 07:04 AM   #2
IRC R310.1.1, .2: min opening height=24"; min opening width=20" ; max sill height 44"
The Following User Says Thank You to Just Bill For This Useful Post:
rigas (05-20-2010)
Old 05-19-2010, 10:59 PM   #3
Registered User
Rewards Points: 5,216
Little more than that: http://illowaicc.org/uploadedFiles/I...20Openings.pdf
Must meet the minimum 5.7 rule unless at grade.
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
rigas (05-20-2010)
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Basement Window Replacement MikeyL Building & Construction 1 05-27-2009 07:08 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Basement window recessed in foundation Freaka Building & Construction 4 11-09-2008 07:15 PM
DIY Egress window in basement? ClnlBrahm Building & Construction 5 09-03-2008 12:15 PM
