Beadboard Wanscoat In Basement To Studs? - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-13-2012, 07:39 PM   #1
Rewards Points: 83
beadboard wanscoat in basement to studs?
hi,
A few questions....has anyone ever used beadboard to finish the lower part of a wall, wanescoat, in a basement?
Do I need to drywall that hidden portion, or can I simply attach the beadboard to the bare studs, and then drywall normally above to ceiling?
Thanks!
D270 is offline   Reply With Quote
Old 12-13-2012, 07:59 PM   #2
Haverhill Trade 1965
Depends how thick the bead board is determines how good it will look. It should project beyond the drywall. You also have to block between studs if it goes parallel with them. Finishing the bottom of the drywall to it could be difficult.
Duckweather is offline   Reply With Quote
Old 12-13-2012, 08:34 PM   #3
Rewards Points: 83
good points. I was wondering if Code required drywall backing as well.
If drywall is not required then I guess I could save some material costs.
Is drywall required behind the beadboard?
Old 12-13-2012, 08:59 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
^ yes, tape the drywall also so that it is air tight.also, there is a backer trim that works good on top of the beadboard and finishes it out.
hand drive is offline   Reply With Quote
Old 12-14-2012, 07:05 AM   #5
Rewards Points: 83
So if I understand correctly, using a bead board wanscoating actually will increase material costs, since there must, according to Code, be drywall there anyway.
correct?
Old 12-14-2012, 07:25 AM   #6
AHH, SPANS!!!
most here will not know your codes, but having a tight seam proof and fire sealed wall is/should be standard in every home. just curious, how would you finish out the transition between bead board and drywall if there were no drywall behind the beadboard? beadboard is less than 3/8" thick and drywall is a full 1/2" thick. there are mouldings that are profiled to fit on top of the beadboard but not the other way around
Old 12-14-2012, 08:37 AM   #7
Beadboard panels are 3/8" but 1 x 6 or 8 beadboard is 3/4". If you get into a stairwell you may need fire blocking and drywall. Just for info, The US Gypsum Handbook gives all drywall a fire rating around 1 hour for 1/2" to completely penetrate it.
Old 12-14-2012, 12:10 PM   #8
Rewards Points: 83
I was thinking I would have "shims" or spacers of drywall pieces to set the correct spacing. The top would be drywalled so I will have some scrap pieces.
The bead board would overlap the drywall at the top then scraps would be used for the bottom and contact points.
Thinking of it, Paneling is still allowed like in the old basement growing up, so I guess beadboard shoukd be fine.
Old 12-14-2012, 02:21 PM   #9
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,124
i stick frame basement walls in renos mainly because the old slabs are hardly ever even which means you can have a huge variation in studs lengths. if every stud works out to being within 1/8" of one another you can prebuild the wall and put it up.. the only different thing i do though is the bottom plate is already fixed. the studs arent nailed to the bottom plate only the top.. stand up the wall first then hop the studs up onto the bottom plate.. doing this allows you to get the wall standing up straight first and it doesnt destroy or pull off the vapour barrier...
woodworkbykirk is offline   Reply With Quote
Old 12-14-2012, 02:23 PM   #10
most regions require drywall behind the wainscotting for fire code reasons. i know some guys that will put 1/2" plywood on the wall up to the height of the panelling mainly to provide solid nailing
Steel studs rust basement help bergerdude Building & Construction 17 10-02-2013 01:24 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 10:09 PM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 10:50 AM
Insulating basement - questions jtmann HVAC 7 11-19-2010 03:20 AM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
