Beadboard Wainscotting Walls In Bathroom - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-04-2013, 04:48 PM   #1
Rewards Points: 31
Beadboard wainscotting walls in bathroom
Thinking of adding beadboard to the walls in a small bathroom. The walls are currently tiled, bottom half of the wall in most of the room, and the entire wall and ceiling in the shower. I would rip off the tiles and attach the boards to the sheetrock.
Looking for ideas for what to do with the walls inside the shower. Should I put the boards up the shower/tub and then keep the tile? Can the beadboard sheets be used in the shower area? Is there something else to use on the walls and ceiling of the shower? Also should mention that the beadboard would be white, while the tile is an off-white or tan in color.
Also worth mentioning, I don't have an exhaust fan in the bathroom so moisture is sometimes an issue.
jmorc2003 is offline   Reply With Quote
Old 01-04-2013, 04:59 PM   #2
Rewards Points: 13,256
Post some pictures!
Bead board has no place in a wet area!
In the wet areas it can be tiled or at least tiled up to about 5' and sheetrocked the rest of the way with green board or paper less sheetrock.
I can not stress enough how important it is to have an exohost vent that runs all the way to the outside of the house!!!
Duckweather (01-05-2013)
Old 01-04-2013, 05:20 PM   #3
Rewards Points: 578
If you are going to put that prefinished beadboard anywhere in your home, do yourself a favor and get an oscillating multi-tool with the Dremel universal adapter and the Dremel wood-cutting blade. NOT the circular blade, the long skinny blade that has Dremel Wood printed across it. We used this board in the kitchen, and this tool is a lifesaver. Jigsaws and circular saws destroy the white finish, utility knives wont cut it, and reciprocating saws tear it up. And Joe is right, it has no business in a wet area. Its made of masonite board, it will disintegrate. What you could do is get some real wood beadboard (more expensive, but much more durable) and paint it with moisture-blocking paint and primer, and put that in your bathroom, but not the prefinished paneling stuff. But inside your shower, i would still use tile with a waterproof backerboard and waterproof membrane. If you have ever watched Holmes on Homes or Disaster DIY you will know that grout is not waterproof! You must have a backer!
TrailerParadise is offline   Reply With Quote
Old 01-04-2013, 06:49 PM   #4
Rewards Points: 31
So are you saying that beadboard in general is not ok in a bathroom? Or just not the shower area?
Old 01-04-2013, 07:33 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
you can use a jigsaw or circ saw no problem, you either cut from the backside of the panel or use masking tape and tape the base of the saw first. pros do it this way every day without issue
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Old 01-05-2013, 12:52 AM   #6
It's fine of you use a real wood or those high dollar vinyl pieces.
That prefinished MDF paneling is junk and will not hold up.
Old 01-05-2013, 03:02 AM   #7
Rewards Points: 578
Kirk, the real wood stuff will cut with those tools no problem, but the prefinished masonite board will not, it will destroy the finish. Trust me, i just did a whole room in this stuff and used every one of those tools i mentioned. i destroyed three boards.
Old 01-05-2013, 04:58 AM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Never put wood in a shower
The Following User Says Thank You to chrisn For This Useful Post:
ToolSeeker (01-12-2013)
Old 01-05-2013, 08:09 AM   #9
ive installed thousands of feet of it and ive never had issues, sounds like your using the wrong jigsaw blade or your using a circ saw blade thats dull or not high enough a tooth count.. for finish work you have to use a 40 tooth circ saw blade.. a craftsman doesnt blame the tool he knows how to adapt and change things so they always get the results they want
also 3 boards isnt a big deal, if you allow for waste and 5% error in your estimate it wouldnt have been an issue.
Old 01-05-2013, 11:04 AM   #10
A few tips for installing it.
All seams need to be sitting on a stud.
Install about 1/2 up off the floor. For two reasons, it can not wick up water on the floor and floors are never level. Just snap a line and set them to the line.
Before installing look around to see where it's going to come up in relationship to any outlets, the top of the sink, any windows.
The standard heigth would be 32" so you can get three pieces out of one 8' sheet.
Start in the middle of the wall to the cuts on the ends will be about equal.
Scrib in the end cuts, sometimes I use a sander to fine tune the inside corners so there tight enough you do not need that ugly inside corner moulding.
Use Loc Tite Qwick grip so you need less fastners. I use a hand floor roller to run across the face of the sheets to level out the glue. A rolling pin will work.
Done right you should only need nails at the seams and a very few top and bottom. The panel cap and base boards will hold it tight to the wall.
Old 01-05-2013, 11:14 AM   #11
Haverhill Trade 1965
Ever try the saber saw blades that have teeth that cut downward? Harder to hold down but can cut from the finish side.
Duckweather is offline   Reply With Quote
Old 01-05-2013, 11:26 AM   #12
Works fine but the saws sole can leave marks unless you use some blue tape.
Old 01-05-2013, 12:33 PM   #13
i hate those blades i just use coping blades by bosch
Old 01-05-2013, 11:24 PM   #14
Rewards Points: 578
Sounds like a lot of headache when you can easily use an oscillating multi tool and get it over with. No tape required, no special blades, the blade is $4. OP, if you want to save yourself a lot of time, a lot of energy, and a lot of money, use an oscillating tool. Those sheets are expensive.
Old 01-05-2013, 11:27 PM   #15
I agree, my ossilating saw and my drill driver are my go to tools for a ton of jobs.
TrailerParadise (01-06-2013)
Bathroom paint peeled off walls! Please Help Keatgsr07 Drywall & Plaster 5 06-23-2012 11:54 PM
bathroom walls jhnhunter Kitchen & Bath Remodeling 1 11-02-2011 09:31 PM
bathroom walls sheilagirl Painting 7 03-27-2011 06:42 PM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 02:20 PM
Beadboard chair rail over uneven walls pmoe Carpentry 8 02-21-2009 10:27 AM
