Beadboard With Non-framed Room Openings - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-24-2014, 12:02 PM   #1
Beadboard with non-framed room openings
I am planning to install beadboard on the lower 1/3 of my gameroom walls. However, there are 4 room openings that lead to the kitchen, living room, and laundry room that do not have frames or doors. These openings also have bull-nose round corners. Traditionally, it would be easy to stop the beadboard on the edge of a door frame. However, I am unsure how to stop the edge of the beadboard on the openings without the leading edge of a frame to butt up against. What is the best method in doing so?
I am a first time home owner and this is my first home improvement project. A lot of terms I am new to so please bare with me
bbohannon06 is offline   Reply With Quote
Old 01-24-2014, 12:10 PM   #2
Rewards Points: 14,312
Not the best look but your going to have to " picture frame" it.
Just stop it short before the opening and add vertical trim.
Sort of like this.
http://www.bing.com/images/search?q=...lectedIndex=15
Old 01-24-2014, 12:44 PM   #3
With what time of trim to picture frame? Should I use the same vertical trim in the corners so it doesn't look out of place?
Also, the link you provided only applied to cased/door framed rooms.
Old 01-24-2014, 01:38 PM   #4
K&B Designer
Live_Oak's Avatar
Just don't do it. Beadboard is a country look and you have a pretty contemporary home. The two don't mesh.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
The Following 2 Users Say Thank You to Live_Oak For This Useful Post:
joecaption (02-06-2014), Windows on Wash (02-07-2014)
Old 02-06-2014, 07:58 PM   #5
I disagree. In addition, that is not what the topic is about.
Any ideas?
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 02:49 PM
Assessing value of layout changes mbianco General DIY Discussions 6 07-21-2012 11:48 PM
Vapor Barrier on elevated 4 season room Indyc0lt Insulation 3 09-15-2011 01:41 PM
Large metal "tabs" in openings cut in bi-level rim joist... What are they? Insulate? nutlog Building & Construction 9 11-09-2009 03:19 PM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 07:28 PM
