bbbasement reno
Im doing a basement reno the electrical was pre wired and there is a rough in for a washroom both were done from the builder. I want to finish the basement myself and was wondering if I need permits. Im going to change some electrical and add a washroom wich im getting permits and hiring someone, but the framing insulating and drywall and sub floor Im doing myself do I need a permit to do those? im in ontario thx
I believe you do need (and want) a permit. There will be inspectors in the house for the future work--
--If they see new work and no record of a permit--you are in trouble. Basement permits should not be difficult to pull-----Read the code book before applying--That will head off the problem of leaving necessary items off the application. A Canadian will be along soon enough to give you local advice.--Mike--- P.S.---Add your location to your profile--you will get local code info that way.--Good luck-- |
| All times are GMT -4. The time now is 06:53 AM. |
