Bathtub And Surround Project - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-02-2013, 09:33 PM   #1
Rewards Points: 150
bathtub and surround project
So one of my baths was pretty rotten. Im still not sure what route Im going to take to fix it. Anyway heres some pics of the damage. What have I got myself into?
Arsinek is offline   Reply With Quote
Old 02-02-2013, 11:52 PM   #2
Rewards Points: 13,300
That tub should have been covered with cardboard before doing any of that demo. It may be damaged already.
Makes no since to me to try and work over a pile of trash like that.
Your going to have to strip that down to the studs, kill all the mold and replace any rotted wood.
Shim out the studs until it even with the lip on the tub.
Insulate any outside walls.
The best enclosers are nailed to the studs with roofing nails and sheetrock is used above the enclosure.
The cheap thin ones get glued up over Green board. (moisture resistant drywall)
Both will need to be shimed to make up for the space lost space from removing the old tile and mud.
Old 02-03-2013, 07:15 AM   #3
I think what Joe was trying to say is, why bother touching the same rubbish twice? The insulation could have been deposited into a garbage bag the first time it was handled. But never mind you work the way you see fit.
Since I don't speak graffitieze I was wondering what does it say?
creeper is offline   Reply With Quote
Old 02-03-2013, 07:26 AM   #4
Just a pet peave I have I can not stand a dirty job site.
A dirty site is a dangerest site. I have trash cans, trash bags and dump trailer on site even before the tools get there.
Old 02-03-2013, 07:33 AM   #5
Thats a good habit to have Joe. It would definitely make the worker more efficient. I'm sure the customer appreciates it as well
Old 02-03-2013, 08:30 AM   #6
Every single customer has mentioned it.
At the end of the day 99% of the time at the end of the day there's 0 trash left any place.
When stripping a roof I have people on the ground cleaning up as fast as it falls.
All it takes is one trip or one nail in the foot to ruin someones day.
Old 02-03-2013, 08:55 AM   #7
When I bought my house the roof had just been done for the point of sale. Later that year when I opened the pool I found at least 1/2 dozen roofing nails in there and countless others around the perimeter. I still find one from time to time
Old 02-03-2013, 08:57 AM   #8
It's impossible to get them all.
When your using that stripping shovel and poping the nails they can fly a long ways.
Old 02-03-2013, 09:27 AM   #9
Rewards Points: 150
Ya, it might have been a good idea to bag it all as I went. Thats what Ill be doing today. As far as the tub, I plan on getting a new one.
Old 02-03-2013, 10:38 AM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 1,142
Based on the 'writing on the wall', I'm guessing this was one of those foreclosed houses?
As for clean up....I have found that it's a lot easier to clean up as I go....it helps me find all the tools I misplaced, and it makes it a lot easier to work.
I've pretty much worn out my shop vac on this project.....
Old 02-03-2013, 10:47 AM   #11
When doing work like that make sure you use a real shop vac not your home vac, unless you want to have to go buy a new one.
I've had good luck with the Ridgid brand vac's. Do not buy the smaller one, hard to find the filters and the hose is to small and stays plugged up.
Old 02-03-2013, 10:50 AM   #12
JOATMON
ddawg16's Avatar
Quickest way to piss off the wife is to use her nice carpet vac.....
Like Joe said...get the larger one....I think the hose is 2.5"....you'll spend less time clear blockages.
I have one of the smaller "Shop Vac" portable jobs...fine for dragging into small places, but I spend a lot of time clearing the hose of obstructions.
One suggestion.....get one of those 'rags' you can put over the filter.....especially if your sucking up drywall dust....the filter will last longer.....but you have to clean the rag off a bit more often....which is a lot easier to do than the main filter.
Old 02-03-2013, 10:56 AM   #13
They sell drywall bags just for this.
Cheese cloth also works.
Old 02-03-2013, 11:01 AM   #14
JOATMON
ddawg16's Avatar
HD sell those? I'll be starting drywall in about 4 weeks....I hope.
Old 02-03-2013, 11:18 AM   #15
Rewards Points: 150
I have a question, why did this happen? Was the tile not installed properly or does this always happen over time?
Trying to decide how to do bathtub surround qoncept Remodeling 11 11-29-2012 10:59 AM
Question on Bathtub surround and floor Tile Install veesmack323 Flooring 15 02-27-2012 04:01 PM
Ceramic Tile around a Surround Bathtub that has been cut LittleRascals Flooring 1 10-03-2011 01:12 PM
Gap in Corner Between Tub Surround and Bathtub? Howitzer Remodeling 12 09-17-2008 05:14 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
