So one of my baths was pretty rotten. Im still not sure what route Im going to take to fix it. Anyway heres some pics of the damage. What have I got myself into? :laughing:
That tub should have been covered with cardboard before doing any of that demo. It may be damaged already.
Makes no since to me to try and work over a pile of trash like that.
Your going to have to strip that down to the studs, kill all the mold and replace any rotted wood.
Shim out the studs until it even with the lip on the tub.
Insulate any outside walls.
The best enclosers are nailed to the studs with roofing nails and sheetrock is used above the enclosure.
The cheap thin ones get glued up over Green board. (moisture resistant drywall)
Both will need to be shimed to make up for the space lost space from removing the old tile and mud.
I think what Joe was trying to say is, why bother touching the same rubbish twice? The insulation could have been deposited into a garbage bag the first time it was handled. But never mind you work the way you see fit.
Since I don't speak graffitieze I was wondering what does it say?
Just a pet peave I have I can not stand a dirty job site.
A dirty site is a dangerest site. I have trash cans, trash bags and dump trailer on site even before the tools get there.
Every single customer has mentioned it.
At the end of the day 99% of the time at the end of the day there's 0 trash left any place.
When stripping a roof I have people on the ground cleaning up as fast as it falls.
All it takes is one trip or one nail in the foot to ruin someones day.
When I bought my house the roof had just been done for the point of sale. Later that year when I opened the pool I found at least 1/2 dozen roofing nails in there and countless others around the perimeter. I still find one from time to time
Based on the 'writing on the wall', I'm guessing this was one of those foreclosed houses?
As for clean up....I have found that it's a lot easier to clean up as I go....it helps me find all the tools I misplaced, and it makes it a lot easier to work.
I've pretty much worn out my shop vac on this project.....
When doing work like that make sure you use a real shop vac not your home vac, unless you want to have to go buy a new one.
I've had good luck with the Ridgid brand vac's. Do not buy the smaller one, hard to find the filters and the hose is to small and stays plugged up.
Quickest way to piss off the wife is to use her nice carpet vac.....
Like Joe said...get the larger one....I think the hose is 2.5"....you'll spend less time clear blockages.
I have one of the smaller "Shop Vac" portable jobs...fine for dragging into small places, but I spend a lot of time clearing the hose of obstructions.
One suggestion.....get one of those 'rags' you can put over the filter.....especially if your sucking up drywall dust....the filter will last longer.....but you have to clean the rag off a bit more often....which is a lot easier to do than the main filter.
Well all the debris is cleaned up. Im not sure what to do next. The pieces of dry wall that went up against the tub and have rot on them also make up some of the main wall. Im not sure how much dry wall to remove.
That looks to be at least 40 or 50 years old.
Grout is not waterproof, what's the chances anyone ever living there ever took the time to seal the grout, or redid the caulking at the bottom of that tub?
If the drywall is removed the tub can be brought into the room on its end---then tipped on to the floor--the skirt will have to go into an open stud bay as it goes down---then slide the tub into place-
I've never failed ,even with a deep tub---so it can be done---how's your back?
I went to Lowes sunday and was looking at the tubs, I asked the guy there and he gave me the same advice. So I guess thats what Im going to do. This weekend Im going to really have to figure out what dry wall needs to go. Im thinking a decent amount might come out. I found out that the wall behind the toilet doesnt seem to be attached on the bottom, so Im guessing I should probably tear that out.
Is there something other than drywall I can use for the walls? Something more water resistant?
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
