Bathtub Surround - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-20-2009, 10:46 PM   #1
Rewards Points: 109
Bathtub Surround
I am having an issue with my new tile I am installing. I ripped out a old fiberglass tub / shower 1 piece about 6 foot tall. I replaced this with a standard 60 x 30 inch tub. I put plastic on the studs for a moisture barrier and glued this to the tub and to the other plastic. I then placed the backer board on the studs. My question is however I am uncertain on how to do a transition between the tile and the drywall. It seems i was supposed to put drywall on then the backer board? since i did not do this the tile is pretty much flush with the drywall.. (see attached) any suggestions would be greatly appreciated.
Bathtub Surround-img_0153.jpg   Bathtub Surround-img_0154.jpg   Bathtub Surround-img_0155.jpg   Bathtub Surround-img_0156.jpg
mchipser is offline   Reply With Quote
Old 09-21-2009, 12:26 AM   #2
The backer should have been flush with the drywall. That is done with furring strips, not drywall. The backer and drywall also should have been taped, thinsetted and mudded. I can see this wasn't done, so the question is, what to do about it? Well, could start over. I'm not sure how you feel about that, chances are not good. I suppose you could caulk the line between the tile and drywall, hopefully the line would be outside any area that could get wet if the tiles go to the ceiling in the shower area.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Old 09-21-2009, 07:28 AM   #3
Rewards Points: 109
yea it is outside of any area that would get wet. What do you think of overlapping a edge piece of tile over the tile and sheetrock?
Old 09-21-2009, 10:50 AM   #4
I suppose you could give it a try. Keep in mind that caulk is not the end all to water problems. A row of tile over the exsisting tile and sheetrock along with caulk along the line would be better than nothing. How long it will last is another thing. I have my doubts, keep an eye on it, if it looks like the sheetrock is start to mold or come apart, you have a water problem.
Old 09-21-2009, 11:01 AM   #5
Rewards Points: 109
I understand.. I just don't want to wast the money I already spent on it, but I guess if I don't fix it now then I may spend more money fixing it in the end anyway.
Old 09-22-2009, 07:35 PM   #6
interesting pictures. I am doing a backsplash that actually requires me to have the tile flush with the drywall. I plan on just caulking the transition between tile and drywall. I am more concerned about how the finished product looks than with water infiltration though.
EBaller55 is offline   Reply With Quote
Old 09-23-2009, 08:22 PM   #7
Rewards Points: 109
So here is what it would look like with a "border" tile over the gap..
Bathtub Surround-img_0157.jpg   Bathtub Surround-img_0158.jpg   Bathtub Surround-img_0159.jpg
Old 09-08-2011, 03:35 PM   #8
Rewards Points: 109
I never posted back.. I ended up redoing everything ripping it all down and adding Sheetrock / backerboard to bring it above the current Sheetrock.. I then trimmed the edge with a decorative piece all the way around and to the ground.. It looks pretty good for my first try .. ( second if you count the first try (: )
Old 09-08-2011, 04:27 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Good Lord!!!
It does look good tho.
XXX
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Bathtub surround???? organick Tiling, ceramics, marble 2 09-11-2009 08:00 PM
Gap in Corner Between Tub Surround and Bathtub? Howitzer Remodeling 12 09-17-2008 04:14 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
