Bathtub Seal - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-08-2012, 08:37 PM   #1
Bathtub Seal
I live in a 1930's apartment building, and the bathroom has the original white and turquoise colored tile. I'm re-sealing between the wall tile and the bathtub. I believe the wall tiles are porcelain. I have DAP Kwik Seal and I have DAP Alex Plus Acrylic Latex Caulk with Silicone. The Kwik Seal doesn't seem to harden. After 24 hours, it's still soft, like modeling clay. I want the caulk to be permanent, but flexible, even a little hard. Should I use the Alex Plus instead? The area nearer the shower head, where I stand when showering, gets a lot of direct water splash during showering and seems to wear out much more quickly than the rest of the caulk around the tub. Right now I have a plastic bag taped to the ceramic tile covering that trouble spot, while the caulking dries, but it won't seem to dry. Should I try something different? Will that Alex Plus be a better choice?
Thanks.
Hypnotised is offline   Reply With Quote
Old 04-08-2012, 09:23 PM   #2
DIY staff
Rewards Points: 7,174
You are using a water soluable caulk---that will always fail---100% silicone will work---it's a bit tricky to install without making a mess---there are ways to do it neatly---Mike---
Old 04-08-2012, 09:36 PM   #3
Mike,
I'm new at this. Thanks. I see now my mistake. I looked up silicone caulk online and I see that it's water resistant. Now I got it.
Will this DAP Alex Plus w/Silicone work, or should I just get the 100% silicone kind?
Link:
http://www.dap.com/product_details.aspx?product_id=2
Tom
Old 04-08-2012, 09:58 PM   #4
DIY staff
Alex is not good in a wet area---
Here is the easy way to install 100% silicone---
Surface must be clean and bone dry---use a razor blade to clean off all old caulk--hair dryer to make sure its dry--
Remember this--Silicone caulk will stick to any clean dry surface--it will not stick to a wet soapy surface---
With this method--always start at the bottom and work your way up---
Cut the tip of the tube--small opening--poke the seal inside the tube with wire--
Apply a thin bead of caulk--make sure you don't leave any voids--
Imediately spray the wet silicone with 'Greased Lightning' or '409' cleaner--spray your finger--tool the caulk with your finger---remove excess to a paper towel.
This is how the granite counter top installers get that fine perfect bead of caulk--Good luck--
Practice on something first if you want to---Mike---
Old 09-28-2012, 12:20 AM   #5
I'm sorry. I forgot to thank you for this great advice! Greatly appreciated!
Old 09-28-2012, 12:21 AM   #6
Thank you! Great advice. Appreciated.
Tom B.
The Following User Says Thank You to Hypnotised For This Useful Post:
oh'mike (09-28-2012)
Old 09-30-2012, 09:51 AM   #7
AHH, SPANS!!!
Rewards Points: 1,166
Also, use a kitchen and bath caulk, the regular caulk with silicone added will grow mildew on it in no time...
hand drive is offline   Reply With Quote
Old 09-30-2012, 01:36 PM   #8
That's exactly my problem. That, AND splitting apart. I'm going to use 100% silicone, or have building maintenance use it. They've been using the wrong stuff. Appreciate it.
New Bathtub Faucet Wont Seal Tightly ILOVECAKE Plumbing 15 09-20-2011 11:02 AM
Fernco wax free toilet seal question? masterblaster4 Plumbing 2 07-21-2011 10:56 AM
To seal or not to seal tops of IPE rocketdoctor Building & Construction 3 09-20-2009 12:04 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 05:45 AM
