Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-15-2009, 12:16 PM   #1
bathtub reinforcement needed?
new second floor bathtub in a 1950's house. Floor joists in that area span about 10 feet and are 2x8 @ 12"-14" O.C. Want to install a modern 5'-5" fibergalss jacuzzi-type tub. Is present framing sufficient for that kind of load? Thanks in advance.
tpagel is offline   Reply With Quote
Old 12-15-2009, 01:30 PM   #2
Remodeling Contractor
you should be fine
Old 12-15-2009, 01:33 PM   #3
Thanks, Bob!
That is really the answer I was hoping for! Did not relish the idea of ripping up subfloor to sister in joists above finished first floor space!
Old 12-15-2009, 01:56 PM   #4
Chicago, IL
Michael Thomas's Avatar
If you intend to install ceramic tile, and can do so without creating too many problems with floor level transitions, you might want to consider adding an additional layer of glued and screwed sub flooring to further stiffen the floor.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs
Michael Thomas is offline   Reply With Quote
Old 12-15-2009, 02:55 PM   #5
Great idea, Michael. What thickness? 1/2" or 3/4"?
Old 12-16-2009, 04:39 PM   #6
you will want a total of 1 1/8" to 1 1/4" for a tiled floor. You need to check what you have there now. Normally another 1/2" is fine.
Old 12-16-2009, 07:30 PM   #7
Chicago, IL
Also, to the extent possible lay it perpendicular the existing flooring, and with staggerd ends, and with seams not aligned with seams below.
Also, if it works in terms of height, 3/4" or even 5/8" is considerably stiffer than 1/2"
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 11:24 AM
How much reinforcement needed? markley Building & Construction 12 08-04-2009 11:28 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
Refinishing bathtub or installing new one? gante General Discussion 7 06-23-2008 03:54 PM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 06:45 AM
