Bathtub Options - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-11-2012, 03:32 PM   #1
Rewards Points: 87
Bathtub Options
Hi Ya'll,
Need some advice on my master bath renovation. My bathroom is rectangular shaped, with one part of it 61" wide. This one part is where I plan on placing a 60" drop in bathtub. I've got most of the details figured but wife and I are discussing the apron for the tub.
This apron will be the only side open to the bathroom. Once the tub is in, we're going to lay down tile flooring. So here's the question finally. The wife wants to do a custom wood apron that matches our cabinetry. We used appalacian oak. I figure the granite top would overhang by an inch.
If I go the wood route, what precautions should I take to keep it from getting water damaged from the bottom? Leave it an inch? What do you think?
Thanks,
Tim
myowneq is offline   Reply With Quote
Old 06-11-2012, 06:47 PM   #2
Rewards Points: 6,652
Keep it just a bit off of the tile, then caulk the seam. Problem is, wood will get wet, and even if you find a way to use a vacuum method to pull the marine grade polyurethane into pores, later on, the poly will wear off the face.
Old 06-12-2012, 01:02 PM   #3
DIY-er
There are ceramic tiles that look like wood and come in a variety of shapes and sizes. We did this for our bathroom so that we have the look of wood without the maintenance issues.
KevinPh is offline   Reply With Quote
Old 06-13-2012, 12:03 PM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
If this is just an occasionally used tub, I'm not sure you would have a significant water problem.
If this is a daily used tub/shower combo, you may want to rethink the drop in tub.
Bathtub/ shower tiling buju Tiling, ceramics, marble 37 08-07-2012 07:03 PM
Basement bathtub drain options? Siubeer Plumbing 9 05-14-2012 10:26 PM
GFCI wiring for a jetted bathtub couchpotato Electrical 13 03-20-2012 11:26 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 05:45 AM
