Bathtub Drain With Oversized Flange - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-21-2011, 10:08 AM   #1
bathtub drain with oversized flange
I am in the process of remodeling my bathroom. My existing tub is in good condition with the exception that there is a small amount of rust around the drain flange. This is not hard water surface rust, it is into the cast iron. I am replacing all of the existing plumbing including drains. If I can come up with a new drain that has an oversized flange outer diameter, it would cover this rust area and I could avoid replacing the entire tub. Does anyone have any leads. I am a newby to this forum. Any help would be greatly appreciated.
jlsdcen2 is offline   Reply With Quote
Old 03-25-2011, 12:52 PM   #2
Rewards Points: 5,336
If the cast iron is rusting, it will continue and blow out the porcelain coating on top.
I'd just replace it now.
Ron
bathtub drain with oversized flange jlsdcen2 Plumbing 4 03-27-2012 05:43 PM
Toilet Flange Inside or Outside Drain Pipe? sledged Plumbing 23 01-18-2012 01:18 PM
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 11:40 PM
I clog my bathtub drain with hair-solution works for me gailquilter2 Plumbing 7 08-22-2010 11:11 PM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 11:24 AM
