-   -   Bathtub Caulk (http://www.diychatroom.com/f15/bathtub-caulk-3447/)
billinak 08-11-2006 11:22 AM
Bathtub Caulk
I've got a gap between the bathtub and wall tile of about 3/4" that doesn't seem to want to keep caulk. The caulk typically splits, or gets holes in it, or becomes discolored. I'm using indoor/outdoor 50-year caulk, so I don't think that's that problem. Should I try and fill some of the space with grout or something first and then caulk?
redline 08-11-2006 05:35 PM
Use grout to fill the 3/4" gap.
If you need to caulk then use mildew resistant caulk made specific for bathrooms.
billinak 08-14-2006 12:02 PM
Thanks, I'll give that a try!
AtlanticWBConst. 08-14-2006 01:36 PM
:jester: Use duct tape, it works on everything. Get it in white to match your grout. :jester:
billinak 08-14-2006 03:30 PM
Unfortunately I used up all of the duct tape extending the header for my kitchen window :laughing:
J187 08-14-2006 03:31 PM
if you need to hide the way it looks afterwards, they sell a nice bathtub sealing strip, like a rubber channel that runs along side. Looks good.
Sellncars 08-14-2006 11:23 PM
I've seen them at Home Depot, but never knew how well they worked. How does it seem to hold up?
Sellncars
J187 08-15-2006 07:19 AM
I used it on a tub where I tiled over existing floor tile and there was a little gap, maybe 1/2 in between the tiles and bottom of the tub. Its been on there now for like, a month or so, and its still holding up perfectly, thats not a lot of time, but it doesn' seem like it'll give me any problems at all. Its nice for a finishing touch. I just filled the seem underneath with kitchen/bath caulking and let it dry for a couple days.
AtlanticWBConst. 08-15-2006 08:21 AM
When I read your post, I was originally thinking the same thing that J187 wrote about (The corner strip-seal tape thingy).
I've used it before on a job about 3 years ago. Haven't gotten a call back yet from them.
billinak 08-15-2006 12:14 PM
It sounds like the product mentioned above is for the gap between the FLOOR tile and the tub, whereas my issue is the gap between the WALL tile and tub.
J187 08-15-2006 02:31 PM
they make one for the floor, one for the walls, one for sink edges, backsplashes, etc etc.
IHI 08-17-2006 04:02 PM
One other trick is you must fill the tub and plug prior to caulking/siliconing this way the tub is "settled" into position with all the weight of the water as opposed to caulking empty tub and then having it "settle" once you go to fill it.
Just dont get alarmed if you hire a contractor and he's in your new tub full of water naked with a caulk gun.....he's just trying to make sure the job is done right:laughing:
It's been years since I used the L shaped caulk strips, but after a while it looks like crap and allows water to seep behind and then we know what happens after that:( As far as caulk I've been having great results with the kitchen/bath mildew resistant silicone. Does'nt seem to turn color or get nasty like the old stuff a few years ago did.
Either way make sure everything is squeekey clean and wipe down with alchol or brake clean so your caulk has a perfectly clean oil free surface to bind to.
J187 08-18-2006 07:06 AM
I hadn't suggest the use of the sealing strips as a replacement for caulk. My advice was to use the strips to dress up the appearance afterward if the caulking didn't look good enough on its own.
billinak 08-18-2006 11:22 AM
Yeah I figured as much. I think I've got the caulk thing figured out, maybe I'll check out the sealing strips for the finishing touch. Thanks for the info!
Trinidiy 05-26-2007 09:51 PM
Hi I'm thankful for your solution to the caulking problem but I'm from another country and need to know the proper name for the strip so I can search for it.
