Bathroom Window - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-12-2011, 02:21 PM   #1
Bathroom Window
Hi! This is my first post here. I have been in my first home for about year year now. The house was built in 1950. In my bathroom there is a window in the shower. The whole shower is tiled with wood trim around the window that the previous owners painted. The moisture from the shower is causing the paint on the wood trim to peel and under it is starting to get mold. I peel the off paint and clean the wood of the mold every time I clean the shower but I was looking for a permanent solution to fixing it without taking the whole window out. We are eventully going to redo the whole bathroom but probably not for a couple of years. And Ideas?
Thanks!!
cchic19 is offline   Reply With Quote
Old 03-13-2011, 08:18 AM   #2
Vinyl replacement window, vinyl trim.
Old 03-14-2011, 05:53 PM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Sorry, but there is really not a solution to your situation. A wood trimmed window just does not belong in a shower. Not only will the wood rot, as you have found, but it will allow water to seep in behind it and cause damage/mold/rot in the wall around it. Even with a vinyl window, you risk this. Best thing is either get rid of the window or if you absolutely have to have a window in there, replace it with transom window well above where any water will hit.
We have a window in our shower, and before remodeling, we just put a tension shower rod with plastic sheeting over it to keep the water from hitting it. Not a perfect solution, but it helped.
If you use a shower curtain, you might get a matching one and cut it down to window size just to pretty it up.
Old 03-14-2011, 06:22 PM   #4
Rewards Points: 1,010
I'd replace it with a glass block window. Still lets plenty of sunlight in but no one can peek on ya from outside. And it's framed in concrete so no worries there either. Plus they're really not that expensive and most places can have it installed in an hour or two.
And where the wood trim used to be you can put in ceramic tiles that match the ones already in the shower.
spaceman spif is offline   Reply With Quote
Window Replacement mark2741 Remodeling 5 07-21-2010 04:33 PM
replacement window for a bathroom Joan Garten Kitchen & Bath Remodeling 2 07-12-2010 07:10 AM
Old Bay Window, lack of support... ogrenjr Building & Construction 6 03-04-2010 10:30 PM
where to put the bathroom window debd Remodeling 3 02-05-2010 12:05 AM
Bathroom ventilation / window privacy issue Michael Thomas General DIY Discussions 10 05-26-2009 10:09 AM
