Bathroom Walls Question... - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-04-2013, 08:23 PM   #1
Bathroom walls question...
Hi, I am getting ready to redo my upstairs bathroom. I'm going to tear out the tub and do a tile shower. My plan is to tile the entire 3 x 8 shower space to the ceiling. So do I need to run the cement board all the way to the ceiling or do I just put it where the old tub was??
Bathroom walls question...-img_0861.jpg   Bathroom walls question...-img_0875.jpg
lylesvegas is offline   Reply With Quote
Old 02-04-2013, 08:34 PM   #2
DIY staff
Rewards Points: 7,174
Just where the tub was is fine----
I do suggest that you water proof the new board with a paint on waterproofing like Red Guard or a surface membrane like Kerdi----
Any thing above the shower head will never get wet enough to worry about---
Old 02-04-2013, 08:36 PM   #3
Thanks, I have read all to much about waterproofing !!!!!
Old 02-04-2013, 10:05 PM   #4
Rewards Points: 12
You might want to take it down to the ceiling. When I tore out my fiberglass tubs I found the drywall had been shimmed out so it laid flat over the tub flange. It may also be easier to lay the tile over a common flat surface vs possibly having a difference due to the thickness of the cement board and drywall.
Dan
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
oh'mike (02-05-2013)
Spray Foam in Walls & Moisture Question leeave96 Insulation 4 11-12-2012 12:43 PM
Expansion of porcelain tile on bathroom backerboard flr and walls? dvarga Remodeling 5 08-08-2011 11:12 PM
Below Grade Bathroom Addition (Concrete / Flooring Question) cmremmert Building & Construction 1 07-12-2011 07:16 AM
Bathroom ventilation question - tight workspace! Hawkeye HVAC 2 08-18-2009 04:31 PM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-23-2006 12:03 AM
