Bathroom Wall Tile - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-04-2008, 04:51 PM   #1
bathroom wall tile
I am installing smooth ceramic wall tiles in the bathroom around the tub. What type of grout is wise to use, sanded/unsanded.
TonyD
TonyD is offline   Reply With Quote
Old 04-06-2008, 12:13 AM   #2
Rewards Points: 33
Hi Tony.
I'm not a pro, but I believe it would depend on the size of the grout joint. 1/8" and less should be unsanded grout. Hopefully a pro will stop in and confirm this.
Bill
ACobra289 is offline   Reply With Quote
Old 04-06-2008, 10:24 AM   #3
Mike
TonyD
Tony,
If you don't want to seal your sanded grout every 6-12months. If you don't want to have to deal with mold, there is only one route for you to go. I install baths/ tubs for home depot, so I know what I'm talking about. You have to go with "acrylic grout". when it dries, Its as hard, waterproof, and easy to clean as the tile itself. E-mail me and I'll get further into the process. Not easy but well worth it.
Mike MJGurrieri01@aol.com
HouseSergeon is offline   Reply With Quote
Old 04-08-2008, 12:54 PM   #4
l1r
Yeah, acrylic modified would do good.
If you really want bulletproof grout, try epoxy. That stuff will stay there after your tiles fall off and house collapses, but it's a true pain in the @$$ to do. Like grouting with honey. Though I think epoxy would be overkill, it is an option.
Sanded or unsanded - it does depend on your joints. Under 1/8" - definitely non-sanded, over 1/8 - sanded. You can mix two if you feel like you have both - wider and smaller joints.
Good luck, and have fuN!
l1r is offline   Reply With Quote
Old 04-09-2008, 01:27 AM   #5
Although epoxy is great, it's not for the person asking about what type of grout to use. That's for sure.
Huge pain in the keister to work with.
albert38 is offline   Reply With Quote
Old 04-09-2008, 08:55 AM   #6
Mike
epoxy grout
What people are saying is true as far as it being a *************** to work with. I've been working withit long enough that I have found ways to make it easier. I've been talking with "Latticrete", the major company that produces epoxy because I have found a way that makes using epoxy easier than plain sanded grout. unfortunately I can't share details because I feel this is going to make me a fortune. We'll see, they say it should become available to the public within 12-16 months. If things work out, you'll be able to do all of your tile and never worry about staining or being waterproof
Mike
8 x 17 Porcelain Wall Tile steve65 Flooring 4 03-19-2008 11:26 PM
Bathroom wall tile Ricksweares Flooring 10 02-26-2008 04:16 PM
Bathroom - tub liner, wall system, etc.??? jlaam Remodeling 7 09-30-2007 09:25 AM
Tile floor or wall first? LX8850 Flooring 3 08-30-2006 01:01 AM
Floor and wall tile question irlizard Flooring 21 07-20-2006 02:35 PM
