Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-09-2011, 11:15 AM   #1
Bathroom wall
We have to tile the bathroom wall around the tub/shower. It will have cement backer on the lower part and the upper part has plaster. I am wondering how to:
make the upper part (see photo) even (patch it? remove more layers?)
How to make sure that the two parts have a smooth transition?
ticia32 is offline   Reply With Quote
Old 03-10-2011, 07:32 AM   #2
Bathroom wall
If the levels are very close, you could skim coat it with drywall compound and sand smooth. What kind of plaster, wood lath or rocklath??? I would be inclined to tear it out and install greenboard for that area. Overlap the tile on the greenboard(plaster) slightly.
Old 03-10-2011, 11:30 AM   #3
Bathroom wall
Agree with Bill, that looks like a pain to smooth out and get even with the bottom.
Ron
Old 03-10-2011, 06:50 PM   #4
Bathroom wall
how about if we add a 1/4 inch cement backer board that goes over the bottom and all the way on the top?
Old 03-10-2011, 09:51 PM   #5
Bathroom wall
Its wood lath. The house was built in 1924. Could I install tile over the plaster base?
Old 03-10-2011, 11:13 PM   #6
Bathroom wall
It depends on a few things.
1 How level is the wall?
-Plaster is notoriously curved in the corners
2. Where is the wall? Shower, then no.
3. How much tiling have you done?
-Can you compensate for the inconsistancies in the wall?
4. Is the plaster all keyed to the lath?
Short answer would be no, I don't think you should tile over plaster.
I know I wouldn't.
Ron
Old 03-10-2011, 11:23 PM   #7
Tileguy
Bud Cline's Avatar
Bathroom wall
Old 03-10-2011, 11:28 PM   #8
Bathroom wall
Its pretty level
in the shower but starting at 3 feet above the tub
no tiling has been done
I know I wouldn't.
Ron
Yes it is keyed to the lath.
I'll take that as a no, bad idea. I was thinking I could put the tile on the brown coat.
How can I make the backer level with the plaster where the tile will meet it? the plaster is a bit thicker.
Old 03-10-2011, 11:32 PM   #9
Tileguy
Bud Cline's Avatar
Bathroom wall
Back up and take another picture.
You can't tell anything from that close up.
Let's see the whole thing.
Old 03-10-2011, 11:37 PM   #10
Bathroom wall
Attach pieces of wood to each stud so it bumps the wall out a bit. When you put on the backerboard, make sure it projects past the plaster a bit(up to 1/8" can by leveled out with compound).
You need to level out the plaster first, then shim out the wall to that build up.
Ron
Old 03-10-2011, 11:52 PM   #11
Bathroom wall
here you go. The bathroom is tiny and the only one in the house.
Old 03-11-2011, 07:55 AM   #12
Bathroom wall
You need to remove all the plaster out of the tub area. You need to insulate the exterior walls.
What you are planning is both a waste of time and money.
Ron
Old 03-11-2011, 02:03 PM   #13
Bathroom wall
Is that siding covering the window?
mserrino is offline   Reply With Quote
Old 03-11-2011, 05:49 PM   #14
Tileguy
Bud Cline's Avatar
Bathroom wall
Ron
Yup!
Any other approach would be a waste.
Old 03-12-2011, 03:21 PM   #15
Bathroom wall
it's the siding from the neighbour's place. Houses in San Francisco are always close to each other like this. It's the only window in that bathroom and as you can see, it's lame. We'd like to put a skylight to get more natural light too but that's probably expensive.
Tags
bathroom, cement backer, plaster, tile, wall
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 07:23 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
venting bathroom out wall mrtmills Kitchen & Bath Remodeling 3 07-13-2009 08:52 PM
Our bathroom wall is rotting out any suggestions??? Darren1977 General Discussion 4 05-17-2009 10:48 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
