Bathroom Upstair - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-04-2013, 02:24 PM   #1
Bathroom upstair
I am wanting to add a bathroom to my upstair attic space. The attic is not very large. The attic is off of the upstairs loft area and is over the kitchen. Plumbing and electrical will all have to be ran. I am trying to figure out if this can be done and a cost estimate. Not trying to make it high end just practical. Also I should say my house is 100 years old. Any suggestions or idea on price would be helpful. Thanks
dsinglet18 is offline   Reply With Quote
Old 08-04-2013, 02:35 PM   #2
Rewards Points: 13,250
No one on the net is going to be able to give you any prices, going to have to just call around locally and get some quotes.More often then not people see all that space and figure why not use it.
A whole lot more to it then just throwing up some sheetrock and flooring.
Going to need to get framing, wiring and plumbing permits.
More then likely the joist will not be wide enough to support a floor.
The open rafters will had to be added onto so there's room for the proper amount of insulation and foam baffles.
A ridge vent will need to be added if there is none.
Knee walls built, HVAC added.
Code approved stars and railing.
And that's just to make an empty room, now add on the cost of fixtures, plumbing, wiring.
Going to be one expensive bathroom.
Old 08-15-2013, 09:23 AM   #3
roofingquotes's Avatar
A bathroom on the attic. Looks like a very hard project and costly. Beside you mention that the space isn't big. Then why thought of putting a bathroom when the space isn't big enough?
roofingquotes is offline   Reply With Quote
Best option for Bathroom Ceiling Paint? tealab Painting 7 04-05-2013 05:49 PM
Columbus Ohio Basement Full Bathroom -Post-Construction Compliance Hermi14 Plumbing 5 03-12-2013 08:11 PM
Rewiring Bathroom & Den heyjoe91 Electrical 4 02-21-2013 05:22 PM
Exhaust Vents - Bathroom and Stove trophywalleye HVAC 0 03-19-2011 11:14 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 10:47 PM
