Bathroom Tub To Shower Remodel... - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-29-2013, 07:38 AM   #1
Rewards Points: 135
Bathroom tub to shower remodel...
I have a few projects going at home but kind of jumped head first into this one. This is my daughter's bathroom and I'm putting in a shower. I finished the demo a couple of days ago. The shower is going to be built using the Kerdi system (already ordered). I will be using Durock on the walls and I will be moving the drain to the center and bringing it up to the 2 inch requirement. All the fixtures will be new as well. The tile for the floor will be installed using Ditra. Anything you guys see from the pictures that I should replace/change/modify now since the walls are down? Any suggestions? All help will be greatly appreciated. Thanks.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
flyboylr45 is offline   Reply With Quote
Old 06-29-2013, 08:12 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,112
Sounds like you have a pretty solid materials plan picked out.
Is that one wall an outside wall?
Be sure to air seal it prior to closing it back up.
Old 06-29-2013, 08:23 AM   #3
Rewards Points: 135
Yes, the one with the insulation is an outside wall. Air seal it? How? There is a plastic liner towards the outside wall. I'm in Florida if that matters.
Old 06-29-2013, 08:33 AM   #4
You will be putting (in the Kerdi system) a vapor barrier to the cold side wall so you will want to make sure that you have some vapor control (i.e. via mitigating solar vapor drive and air movement into the wall system) from pushing into the home.
Pull out that insulation and look for any gaps/cracks in the outside sheathing to seal up very well.
What is the exterior of the home?
Old 06-29-2013, 08:37 AM   #5
Rewards Points: 135
That's the second story so it's all wood with stucco finish. So what about the vapor barrier already there? Do I rip out the insulation, fill any voids with (expandable foam?? or..) and then add another vapor barrier before the Durock and Kerdi?
Old 06-29-2013, 09:24 AM   #6
Pull the FG out. It probably has kraft facing on it.
Fill the gaps with sealant and/or foam.
Old 06-29-2013, 12:16 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
Are you changing out the valves, or at least raising them up? Your bath is laid out like ours is. We wound up with a shower head on both end walls and one over head, we are very happy with ours.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 06-29-2013, 12:41 PM   #8
Rewards Points: 135
Yeap. All valves are going to be changed. If you hadn't brought up the bringing the valves up I would have realized it after tiling!!!!! Thanks!! ;-) We are going to do the multiple shower heads in our shower, but since this is my daughter's bathroom she better be happy with one. ;-)
Old 06-29-2013, 01:05 PM   #9
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 4,652
Yeah... We're sure as heck hypocrits when it comes to our daughters.
MTN REMODEL LLC is offline   Reply With Quote
Old 06-29-2013, 01:17 PM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
Maybe their daughter is too young to enjoy multiple shower heads.
Jim
Old 06-29-2013, 01:45 PM   #11
ALL our daughters are too young....regardless of age... from a Dad's perspective
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
oh'mike (07-18-2013)
Old 06-29-2013, 02:16 PM   #12
Rewards Points: 135
That's it guys, NO SHOWER HEADS. I'm putting in a low flow hose bib. ;-) and yes, they will always be too young.
The Following User Says Thank You to flyboylr45 For This Useful Post:
MTN REMODEL LLC (06-29-2013)
Old 06-29-2013, 05:37 PM   #13
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
I hope you don't think I meant that in a bad way.
Jim
The Following User Says Thank You to BigJim For This Useful Post:
Old 06-29-2013, 06:37 PM   #14
Rewards Points: 135
lol lol . Not in the least bit. ;-)
The Following 2 Users Say Thank You to flyboylr45 For This Useful Post:
BigJim (06-29-2013), MTN REMODEL LLC (06-29-2013)
Old 07-06-2013, 04:09 PM   #15
Rewards Points: 135
Ok. Got back from my trip and continuing my project. Where do you guys think it's best to tie the 2" drain for the shower? I already received the Kerdi shower kit and the drain will be located where the channel begins. I cut this channel after marking with the template. I know I'm going to have to do some framing to support the subfloor after the installation. Don't really know how many bends are allowed or if it even matters. I know that a p-trap has to be installed. Any suggestions? I can always keep tearing up the subfloor to get more access but would rather not.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Basement bathroom shower remodel NewHomeDIYGuy Kitchen & Bath Remodeling 39 11-26-2013 11:20 AM
1930's house (old world charm) bathroom remodel ohman Kitchen & Bath Remodeling 17 11-06-2012 02:01 PM
Copper to pex manifold on bathroom remodel jpeake Plumbing 5 11-16-2010 04:59 PM
Bathroom Shower Remodel Advise Sparkey57 Plumbing 2 03-26-2010 09:59 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 11:33 AM
