Bathroom Tub Leak - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-03-2015, 09:17 AM   #1
Rewards Points: 99
Bathroom tub leak
After discovering a leak around our bathtub we want to change the structure of the bathroom shower/tub. Currently the surround walls are tiled (which was tiled to regular sheetrock). The leak started around the knobs and over time weaped about 15". We noticed the wall paper near the tub edge turned a brown color, so I removed that and started working backwards to find the leak. The drywall was mush and some trim included. There was caulk between the tile and tub, but I cut that out during while looking for the problem. Did not take a picture before I started removing drywall, caulk, and tiles.
I contacted five contractors and we're dealing with continous rescheduling of the appointment or no call back, so my wife wants me to take a few days off from work and we make the repairs. I'd hire out the plumbing since I want a new fixture that requires a new valve.
I would remove all tiles and sheetrock on all three sides of the tub. Install new moisture resistant drywall and tape/mud joints, then install 5 piece glue on shower/tub surround.
Is installing tub surround a really straight forward project?
Bathroom tub leak-gedc0045.jpg   Bathroom tub leak-gedc0099.jpg   Bathroom tub leak-gedc0048.jpg
marriedmanw is offline   Reply With Quote
Old 03-03-2015, 11:16 AM   #2
Rewards Points: 942
Bathroom tub leak
are you sure you don't want to remove old tub at this point as well ..then install a sterling unit that is designed for remodeling as you have tub and walls lock togeother a much better finish product than m/r board and tub surround....just asking.... but to answer your question ..tub surrounds are straight forward but can be tricky if walls and tub are not square and level...
Old 03-03-2015, 11:38 AM   #3
Rewards Points: 99
Bathroom tub leak
Yes, we had discussed replacing the tub and I agree that it would be easiler to do with all three walls removed. I can disconnect the drain line from the basement since bathroom is over top unfinished garage. My wife liked the tub other than the color due to it being metal and would retain the water temperature longer when bathing the kids.
Since we are still in the planning stage, I have not removed it from my list.
Thanks for confirming about the surround walls.
Old 03-03-2015, 01:32 PM   #4
Rewards Points: 942
Bathroom tub leak
welcome
Old 03-03-2015, 01:48 PM   #5
Rewards Points: 773
Bathroom tub leak
Do yourself a big favor and don't use green board. It is only marginally better than regular drywall. Cover your studs with plastic or roofing felt and install Hardieboard. It will never rot out.
Colbyt
Colbyt is online now   Reply With Quote
Old 03-03-2015, 06:14 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,550
Bathroom tub leak
I prefer Duroc and one of the Kerdi membranes or similar technology but anything will be better.
Old 03-05-2015, 10:42 PM   #7
Rewards Points: 106
Bathroom tub leak
Is that a cast iron or steel tub? The original tub is probably more durable than a fiberglass or acrylic tub. If it is not in bad shape and your wife doesn't mind the color, you might consider building a new wall around it. You definitely want to go with a hardi board or durrock as suggested.
Another consideration with water leakage though is the floor. Has the floor under the tube sustained any water damage?
Jim F is online now   Reply With Quote
Mystery - leak or no leak turness Plumbing 4 01-12-2013 07:46 PM
water leak near bathroom entrance rmom@fa Plumbing 2 11-25-2012 11:33 AM
leak in bathroom jilleckert Plumbing 1 11-27-2011 11:55 AM
Leak in condo bathroom abefroman Plumbing 3 07-28-2010 09:59 AM
Bathroom sink supply line leak afarr Plumbing 6 05-26-2010 05:59 PM
