Bathroom Tiling Dilemma - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-28-2009, 01:08 AM   #1
Question
When tiling a bathroom, is it best to tile around a door frame, or if we are replacing the door and frame, is it ok to tile underneath where the new frame will be....and worry about replacing the frame and door later?? Are we creating a headache for ourselves?
Is it ok to at least have the cement board installed under where the door frame will be?
jdcyclone is offline   Reply With Quote
Old 02-28-2009, 03:34 AM   #2
Oldguy
Rehabber's Avatar
The correct way is to tile underneath the door frame.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 02-28-2009, 07:36 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
On wall tiling, I would remove the door and then install my wall board, then install my door and jamb, trim it out and then set my tile. on floor tiling I would install the trim after the saddle is installed. BOB
Old 02-28-2009, 07:59 AM   #4
Remodeling Contractor
Both are correct... CBU under the door, then door, then tile. The tile ends at the inside edge of the door stop. The CBU goes beyond that point so a marble threshold can be installed.
Tiling a bathroom... with uneven floors dianaslik Flooring 14 01-23-2012 09:37 AM
Tiling bathroom ivaiva Project Showcase 3 08-30-2008 09:24 AM
Tiling half a bathroom jeannieB Remodeling 9 06-20-2008 12:44 PM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-23-2006 12:03 AM
bathroom tiling neptunian General DIY Discussions 1 03-29-2005 08:44 AM
