Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-07-2005, 12:07 PM   #1
underqualified shoprocket
Bathroom tile question....
This forum seems like a great find, i wonder if i can get a little general help before i start this bathroom project.
When laying tiles on a bathroom wall, are the tiles layed on top of the green board, on top of a concrete backer board, or do you need the greenboard THEN the concrete board THEN the tile?
also, does greenboard come in a standard thickness or is it a matter of preference like regular drywall?
i appreciate any help
hallbum is offline   Reply With Quote
Old 10-07-2005, 02:09 PM   #2
For me it would be green board or concrete board but not both. Tub or shower concrete for me. Got to work out so the tiles overlay the lip of the tub/shower. Should be some other guys jumping in who know more about it. HS
K2eoj is offline   Reply With Quote
Old 10-09-2005, 06:37 PM   #3
I can't think of any good use for greenboard. It should never be used at a shower wall. It cannot be used over vapor barriers on exterior walls. There are much better materials available these days.
mighty anvil is offline   Reply With Quote
Old 10-10-2005, 10:57 AM   #4
what do you suggest as an alternative to greenboard??
Old 10-11-2005, 09:46 AM   #5
What is the finish and for what kind of use? Cement backer board in a tiled shower always.
Old 10-11-2005, 11:01 AM   #6
rspainhower's Avatar
Anvil is correct. If you are using tile, go with the cement board. Seal the joints and make sure there is a vapor barrier behind the board against the studs.
rspainhower is offline   Reply With Quote
Old 10-12-2005, 10:43 AM   #7
Can you please tell me the difference between Hardibacker board and Durock? I am doing a similar project and have access to both products. I was going to use greenboard, but it doesn't seem to be a popular choice!
I'm installing 6 x 8 wall tile in the tub area. What size joint and/or spacer size do you recommend? I'm using unsanded grout, correct?
Thank you for your help.
fishwi is offline   Reply With Quote
Old 10-12-2005, 12:14 PM   #8
Hardi and Durock are Cement board products made by 2 different companies. They have small differences (the biggest difference is that Durock is made with glass fibers and Hardi is not) but will both work fine for your application. Unsanded grout requires a 1/8" joint or less. Use either a 1/8" or 1/16" spacer. Please tell me a little bit more about your planned install and I can help you more.
Old 10-12-2005, 12:35 PM   #9
Wink
Hi Randy
Thanks for the reply. I'm removing the existing tile to the studs, installing one of the products I asked about earlier, with a vapor barrier on the studs. I'm using thinset to set the tiles as well as sealing the joints between the cement board.
The tile is 6 x 8 with a matte finish. I like the 1/8th" joint so we'll go with that and unsanded grout. I've used Durock once before and remember how difficult it was to cut and drill holes for the fixture wall. Any suggestions? Thanks again.
Mike
Old 10-12-2005, 04:23 PM   #10
Mike,
I like Hardibacker and it is my choice as long as it is not a steam shower. Use the Square drive screws located next to the board at Lowes or HD. Make sure you sink them good. It is good to hear you are using a vapor barrier. Any other questions just ask.
Old 10-14-2005, 01:49 PM   #11
Hardibacker 500 tile backerboard is essentially a wood fiber (cellulose), sand and cement composite panel. It can be used behind tile in a shower but because of it's organic nature it cannot be used in a steam shower. Durock and Wonderboard are essentially inorganic sand and cement (concrete) boards reinforced with fiberglass mesh on it's surfaces. I prefer pure concrete boards in a wet area because they don't lose any strength when they get wet. In terms of ease of installation I don't think a few cuts should determine the quality of the installation.
It is also possible that the owner will want to add steam later.
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 10:22 PM
HELP! Question About Lousy Tile Setting Job... EricW Flooring 10 09-13-2006 08:02 PM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-23-2006 12:03 AM
Floor and wall tile question irlizard Flooring 21 07-20-2006 02:35 PM
Getting ready to tile bathroom floor, question J187 Flooring 4 06-06-2006 01:31 PM
