Bathroom Sink Adhesive - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-31-2012, 02:29 PM   #1
analogmusicman's Avatar
Rewards Points: 560
bathroom sink adhesive
I'll be remodeling a "powder room" off my laundry room and will be getting a vanity top (probably granite or quartz) without a sink. what kind of adhesive should I use to secure the sink?
tnx,
analogmusicman is offline   Reply With Quote
Old 12-31-2012, 03:15 PM   #2
Civil Engineer
Rewards Points: 4,566
I used silicone for my bathroom top and my kitchen island top (both stone). The granite installers used silicone for my granite kitchen counter. Seemed to work very well.
Old 12-31-2012, 03:51 PM   #3
Rewards Points: 560
yeah,silicone is what to use for attaching the counter top to the cabinet, but my question was about attaching the sink to the granite top. I don't think silicone would do it.
tnx,
Old 12-31-2012, 04:12 PM   #4
the china sinks used to come packaged with a tube of latex caulk (polyseamseal) to glue them down to the countertops. its a lot easier to work with then the silicone.
Old 12-31-2012, 05:22 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,820
tnx,
Silicon also works in this case as well.
The Following User Says Thank You to Windows on Wash For This Useful Post:
oh'mike (12-31-2012)
Old 12-31-2012, 05:41 PM   #6
Rewards Points: 13,270
This is what I use.
Holds tight, does not leak, mold resistant, easy clean up, low odor.
http://phenoseal.com/product_details.aspx?product=13
Old 12-31-2012, 07:51 PM   #7
DIY staff
Rewards Points: 7,174
Are you going to use an under mount sink? Ceramic?
I have always let the counter top crew install them---some use silicone--other mix 2 part epoxy
Studs are installed into the granite and metal clips are used to hold the sink until the adhesive sets up---
Old 12-31-2012, 10:26 PM   #8
Rewards Points: 560
yes,it's an undermount sink Mike. it just seems as though the adhesive required would have to be strong, seeing as how there's no "lip" sitting on the counter top. maybe I'm wrong and silicone will work. (I'm PROBABLY wrong!)
tnx,
Old 01-01-2013, 07:32 AM   #9
DIY staff
I've had to remove a few that were secured with silicone---it holds well---
Go look at a fish tank----that is held together with silicone----it'll hold.
Old 01-01-2013, 11:38 AM   #10
Civil Engineer
I have two undermount sinks in my house, one is a stainless steel kitchen sink, one is a ceramic sink. Both are mounted under granite. In both cases, the granite was drilled by the fabricator, and several threaded inserts were installed. The sinks are held in place with stainless bolts that thread into the inserts. Silicone is used between the sink top and the counter for water tightness.
Old 01-01-2013, 11:45 AM   #11
Rewards Points: 560
ok,I'm convinced.silicone it is!
tnx,
slow draining bathroom sink jbkenn331 Plumbing 11 12-07-2012 02:13 PM
Replace bathroom sink drain? Dave321 Plumbing 2 06-07-2011 01:37 PM
Bathroom sink clogged John P Plumbing 3 10-24-2010 04:37 PM
Kitchen sink backing up to downstairs bathroom! macon215 Plumbing 1 09-25-2010 07:41 PM
Caulking around bathroom sink KarenRB53 Plumbing 2 09-17-2009 11:21 AM
