-   -   bathroom sink adhesive (http://www.diychatroom.com/f15/bathroom-sink-adhesive-167880/)
analogmusicman 12-31-2012 01:29 PM
I'll be remodeling a "powder room" off my laundry room and will be getting a vanity top (probably granite or quartz) without a sink. what kind of adhesive should I use to secure the sink?
tnx,
Daniel Holzman 12-31-2012 02:15 PM
I used silicone for my bathroom top and my kitchen island top (both stone). The granite installers used silicone for my granite kitchen counter. Seemed to work very well.
analogmusicman 12-31-2012 02:51 PM
yeah,silicone is what to use for attaching the counter top to the cabinet, but my question was about attaching the sink to the granite top. I don't think silicone would do it.
tnx,
DannyT 12-31-2012 03:12 PM
the china sinks used to come packaged with a tube of latex caulk (polyseamseal) to glue them down to the countertops. its a lot easier to work with then the silicone.
Windows on Wash 12-31-2012 04:22 PM
tnx,
Silicon also works in this case as well.
joecaption 12-31-2012 04:41 PM
This is what I use.
Holds tight, does not leak, mold resistant, easy clean up, low odor.
http://phenoseal.com/product_details.aspx?product=13
oh'mike 12-31-2012 06:51 PM
Are you going to use an under mount sink? Ceramic?
I have always let the counter top crew install them---some use silicone--other mix 2 part epoxy
Studs are installed into the granite and metal clips are used to hold the sink until the adhesive sets up---
analogmusicman 12-31-2012 09:26 PM
yes,it's an undermount sink Mike. it just seems as though the adhesive required would have to be strong, seeing as how there's no "lip" sitting on the counter top. maybe I'm wrong and silicone will work. (I'm PROBABLY wrong!):)
tnx,
oh'mike 01-01-2013 06:32 AM
I've had to remove a few that were secured with silicone---it holds well---
Go look at a fish tank----that is held together with silicone----it'll hold.
Daniel Holzman 01-01-2013 10:38 AM
I have two undermount sinks in my house, one is a stainless steel kitchen sink, one is a ceramic sink. Both are mounted under granite. In both cases, the granite was drilled by the fabricator, and several threaded inserts were installed. The sinks are held in place with stainless bolts that thread into the inserts. Silicone is used between the sink top and the counter for water tightness.
analogmusicman 01-01-2013 10:45 AM
ok,I'm convinced.silicone it is!:thumbsup:
tnx,
