Bathroom Renovation - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-16-2008, 10:20 AM   #16
Another DIY Zombie
Rewards Points: 264
Another option
Not the greatest, but I have done it with floors, is to sister the existing studs with new studs, that are installed plub, such that they protrude past the original studs, into the tub area, such that the drywall would be in the correct position. This would be if your current studs are not plumb and would alleviate having to shim with different thicknesses.
javan is offline   Reply With Quote
Old 07-20-2008, 08:55 AM   #17
HomeAdditionPlus.com
Rewards Points: 29
Use two layers of 1/2" drywall to make up the difference.
Last edited by AtlanticWBConst.; 07-20-2008 at 12:56 PM. Reason: DIY Chatroom Rules Violation: Site Link Removed
mjdonovan is offline   Reply With Quote
Old 07-21-2008, 03:36 PM   #18
Originally Posted by angus242 View Post
OK, here's what I recommend:
#1. If you fir out the studs to accommodate the gap, you'll have to do all of the walls on both sides of the bath. If you fir just the walls inside the tub surround, you'll have an uneven surface between the tub and the rest of the room.
#2. If you plan on tiling the walls in the surround, you need to use cement backer board, not drywall. The material should be 1/2" thick.
#3. Here's what I propose that will allow you to keep the walls as is without firring out everything:
You say the gap is 1/2" total so you center the tub leaving 1/4" gap on both sides of the tub. You shim between the tub flange and the studs. Your wall material is 1/2" thick so you need to notch the bottom of the backer board just above the tub flange. This picture is not to scale but just to give you a visual of what I'm suggesting.
Does this make sense? Also, you never mentioned what the tub surround material is supposed to be? Fiberglass surround? Tile?
Angus, I have a similar problem in that my tub flange does not touch the wall studs. How should I go about notching the backerboard? Also, how would I install and secure the shim you are referring to in your pic if the tub is already installed? I have a cast iron tub.
cooper4x4 is offline   Reply With Quote
Old 07-22-2008, 07:44 AM   #19
K&B Remodeler/Tile Guy
angus242's Avatar
If the tub is already installed, you don't need to shim. The original problem was a tub was being installed and the wall spacing was larger than the tub. That's what the shims would be for.
As for notching, what kind of backer are you using? What do you plan on doing as a wall covering?
Angus
My Albums
angus242 is offline   Reply With Quote
Old 07-22-2008, 08:11 AM   #20
I'll be using cement backer board with tile as a wall covering with a coat of redguard in between.
Old 07-23-2008, 09:50 AM   #21
angus242's Avatar
Depending on what brand CBU you are using (I like Hardi), you can just use a utility knife to make the notch. Perfection is not needed for this. You're just making the CBU fits properly to the flange.
When using RedGard, it is critical that you get 100% coverage over the CBU. Pay close attention to your corners. You may need a few coats and watch out for any bubbles or pinholes.
Good luck!
Angus
My Albums
Old 07-23-2008, 09:55 AM   #22
I am using Hardi for the backer board. How far down the flange does the backerboard need to go? the flange is only about an inch tall
Old 07-23-2008, 10:12 AM   #23
angus242's Avatar
1/8" gap filled with 100% silicone.
Angus
My Albums
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 10:10 AM
Bathroom Renovation shapeshifter Painting 19 02-24-2007 08:32 PM
Bathroom Renovation TonyD Remodeling 6 01-10-2007 11:28 PM
