Bathroom Remodel Snafu - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-19-2007, 10:01 AM   #1
Bathroom remodel snafu
Bathroom is gutted, am installing new fixtures for tub/shower, toilet, and sink. Also installing new drywall ( green board ) , ceramic tile for shower surround and floor.
The problem right now is getting the depth inside the wall for the water valve. The instructions provided are useless ( who writes that stuff ? ).
I had screwed the valve to 2x4 but that was to much, then tried 1x4 which looked like it would work. put up the drywall piece I cut for it and now it is too shallow .
the only thing that comes to my mind is building up with 1/2 in. material behind the valve which will be difficult but not impossible. Any sugestions would be very welcome.
RocknRoller is offline   Reply With Quote
Old 06-19-2007, 11:30 AM   #2
You're having trouble mounting the shower valve at the right distance back from the finished wall?
Why not just mount your 1x4 a little closer to the finished wall? Not as far back between the studs.
Am I misunderstanding the question?
The 1x4 doesn't need to be all the way back in the stud-space.
NateHanson is offline   Reply With Quote
Old 06-19-2007, 12:30 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Use a 2x4 or 2x6 (even better) place on the "flat" between the studs. Also, DON'T USE GREEN BOARD for the walls and tile. Use cement board.
- Build Well -
Old 06-19-2007, 03:21 PM   #4
Custom Cabinet Maker
Atlantic: AMEN BROTHER NO GREEN BOARD Cement board for tile backer and the new paperless drywall for the rest of the bathroom. Darn I cant think of the name of it either, think USG has it out, its even in the Borg boxes
You know what it is fer shure. AHHHHHHHHH DENSHIELD DATS ITmighr b spelled wrong but dats its name.
JackM
Last edited by AtlanticWBConst.; 06-19-2007 at 05:12 PM. Reason: Minor language use
skymaster is offline   Reply With Quote
Old 06-19-2007, 05:15 PM   #5
JackM
Georgia Pacific DENSARMOR (Paperless Drywall)
This stuff:
http://www.gp.com/build/product.aspx?pid=4899
http://www.stopfeedingmold.com/
- Build Well -
Old 06-19-2007, 05:49 PM   #6
SEE ATLANTIC I KNEW YOU KNEW DAT
jACK
Bathroom remodel - what to do first? led0826 Remodeling 2 07-30-2007 01:02 AM
Bathroom Tile Shower Remodel MattCoops Remodeling 2 04-30-2007 05:48 PM
HELP! How should I remodel my bathroom for the highest return profit?? nidaxny General DIY Discussions 2 03-20-2007 12:32 AM
Approach to demo bathroom ceramic tile floor for remodel corky Flooring 3 01-29-2007 09:59 AM
bathroom remodel what brands to use? nat Plumbing 1 11-13-2006 12:07 AM
