#1 |
Bathroom remodel - recessed light above shower
I'm remodeling a small bathroom, this house was built in 78 and i guess they didn't like big bathrooms back then. I've taken it down to the studs so far. The vanity was seperated from the shower and toilet by a wall, which i've knocked down all except for 32 inches to encase the shower. I've also taken out the cheesy overhangs above the shower and vanity.
I'm playing around with lighting ideas, right now there is just 1 light above the toilet area. i really want to bring some light into the shower that we never had before, so I'm thinking about adding a recessed light above the shower, question is what size light to put in? 3,4,5 inch? What light would be suitable for a 60x32 shower mounted 8' above the floor? Does it even matter what size can I buy? Thanks. |
#2 |
Remodeler
Any size is fine. Just make sure it's a waterproof one. I have a 5 or 6 inch one above my tub.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. residential To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. & To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
I actually couldn't find one on home depot's website that was waterproof, it looked like you just buy a regular light and use a special shower cover/lens with it. Is this right?
#4 |
Bathroom remodel - recessed light above shower |
#5 |
Remodeler
Yes, sorry I wasn't clear. You buy a special trim piece that is specifically for wet areas. It sounds like you found it. Usually the lens is frosted and that gives a nice effect to the light.
#6 |
Yes BB you can get any size can light just make sure it has a glass cover (usually has a rubber seal) that will fit the size. Easy to find them at Home Depot for 5" and 6". It might be harder to find in smaller sizes. You can never have enough light in the shower. Really nice ones can even be built into seats. Similar to a pool light. I have one planned for my next master bath.
#7 |
Moderator
Or use a fan/light combo just outside the wet area to pick up the moisture at it's source.
Be safe, Gary |
| Display Modes | |
| Recessed light directly over shower | adpanko | Electrical | 33 | 09-16-2009 07:56 AM |
| please find flaws in my bathroom remodel plans | gregdonovan | Kitchen & Bath Remodeling | 12 | 06-16-2009 11:43 AM |
| Bathroom Ceiling above shower | qvminich | Building & Construction | 13 | 11-07-2008 03:40 PM |
| Steps for Bathroom Remodel? | SeattleHome | Building & Construction | 7 | 10-09-2008 12:04 PM |
| Help, the bakelite light fitting in my shower room smells! | Unregistered | Electrical | 1 | 08-13-2004 08:03 AM |
