Bathroom Remodel Questions - Remodeling - Page 4 - DIY Chatroom Home Improvement Forum
Old 12-17-2009, 08:51 AM   #46
Originally Posted by Vikeologist View Post
My local lumber yard did not have any moisture resistant or greenboard drywall, so I had to get regular drywall...
I am very worried this will cause problems later with mold and mildew. Will I be ok using regular drywall in my bathroom, or did I make a major mistake...
we already have the ceilings up with regular drywall
My bathroom has regular drywall. I wish it had moisture resistant, but it is what it is. There doesn't seem to be any problem in my specific case, although I'm pretty big on running the fan when showering. I get occasional mold growing on the ceiling but I clean it off right away.
pyper is offline   Reply With Quote
Old 12-17-2009, 09:59 AM   #47
so should I tear down the regular drywall and re-do it with moisture resistant drywall?
what about the walls, should I use moisture resistant on the walls, or just continue with the regular drywall? Thanks!
Vikeologist is offline   Reply With Quote
Old 12-17-2009, 12:15 PM   #48
Drywall is fairly cheap and now is the time to do it. Sure you might get away with a well sealed regular dryway, but why risk it?
Haff is offline   Reply With Quote
Old 12-17-2009, 01:33 PM   #49
wow, so I should tear it down and start over huh?
Old 12-30-2009, 03:44 PM   #50
OK I am at the point of getting the subfloor ready before I have the tub installed.
I have what looks to be 2 layers of wood nailed as a subfloor in my bathroom. The floor was squeaky, so I screwed the subfloor to the floor joists.
What do I do next. Do I install plywood over the top, and if so, how thick, and what kind? Do I put thinset in between the subfloor and the plywood? Do I screw the plywood into the joists or just to the subfloor only? Do I run the plywood all the way under where the new tub will be?
After the plywood then do I install a cement board over the plywood, if so, how thick? Do I install the cement board under the tub as well, or should I wait with the cement board until the tub is installed and just install it up to the side of the tub?
Thanks!
Old 12-30-2009, 09:44 PM   #51
Remodeling Contractor
if you have two layers of wood over the joists you may be fine. you need 1 1/8" of sub flooring. But what are these layers? Plywood (exterior grade for top level) should be used. If not you may want to remove one of the two layers and use one sheet of plywood. Even under the tub with this. Then use either 1/4" CBU or Ditra on the plywood prior to tiling. this does not go under the tub. So put the tub in after plywood is installed. Pl400 is used with screws or nails to lay the plywood. Thinset with approved screws is used for the cement backer. Modified thinset to set the Ditra with unmodified thinset to lay the tiles.
Old 12-31-2009, 07:26 AM   #52
no there is no plywood. It looks to be some 3 inch wide boards...not sure if they are tongue and groove or not.
I already screwed this all down to the joists, can I add a layer of plywood over the 2 layers of wood flooring, then add the cement board over that, then the tile over that? how much space am I going to need for this?
how thick of plywood, then a 1/4 inch of cement board, then the tile
Old 12-31-2009, 09:13 AM   #53
yes you can add 1 1/2" exterior grade plywood glued and screwed. Then 1/4" cement board set in thinset and screwed.
Bathroom Remodel - design questions secutanudu Remodeling 24 01-12-2010 07:39 PM
Noob bathroom remodel jep Kitchen & Bath Remodeling 18 11-22-2009 10:56 AM
Bathroom remodel questions. What a mess now timewarp Remodeling 5 01-14-2009 04:43 PM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 11:04 AM
bathroom remodel questions Jeff32 Remodeling 2 08-13-2007 10:36 PM
