Bathroom Remodel.... I Need Ideas - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-19-2013, 08:31 PM   #1
bathroom remodel.... i need ideas
I'm getting ready to remodel my bathroom and I'm going over about how much it will cost me. Everything is coming down drywall to subfloor. The bathtub cracked and flooded the bathroom so everything gets changed. My first question will be moving the shutoff valves to inside the wall. Right now the shutoffs are coming thru the subfloor. The move will 6-8 inches. Do I cut the line and move the entire assembly. Or is there a trick using a bunch of elbows I can do?? Lol
big juicy01 is offline   Reply With Quote
Old 10-19-2013, 09:35 PM   #2
Rewards Points: 582
your location helps us help you ...and pictures...ben sr
Old 10-19-2013, 09:46 PM   #3
Rewards Points: 12,886
Is there access under the floor?
Old 10-19-2013, 10:52 PM   #4
I live in TN. North of Nashville. And there is plenty of crawlspace
Old 10-20-2013, 04:58 AM   #5
DIY staff
Rewards Points: 7,174
Pictures from the crawl space and again from the bathroom will get you answers--also--what type of pipe? Threaded steel? Copper?
Old 10-20-2013, 08:50 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 116
You don't live around Cumberland Furnace do you? I got a buddy up that way, helicopter mechanic.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 10-20-2013, 10:45 AM   #7
Gymschu's Avatar
Rewards Points: 246
I see no reason why you can't cut the supply lines that now come up through the floor. Then you may have to cut them back a few inches more, add 90 degree fittings and bring it up through the sill plate of the bathroom into the wall. Basically you will be redoing it exactly as it was.......just 6 or 8 inches back so you can come up INTO the wall.
*But, yes, pics would help.
Old 10-20-2013, 01:01 PM   #8
PVC is in there now. So that will be what goes back. I'm going to do wall to wall tile then put the tub and toilet back in. I'm just not wanting to cut around supply lines when I go back in with tile. I have vinyl in there now.
Old 10-20-2013, 01:12 PM   #9
I can get some pics up once I leave this cursed holler. I coon hunt the Cumberland around hartsville and Lebanon. Never heard of Cumberland furnace but that don't mean I haven't been there chasing a dog. Right now PVC is what is coming thru the floor. My plan is to lay tile wall to wall and then go back in with my plastic tub and wall surround. Lol
Old 10-20-2013, 08:13 PM   #10
Gymschu's Avatar
Rewards Points: 246
PVC makes this an easier DIY project. I would invest in a PVC cutting tool to make nice, clean, straight cuts. Some primer and glue and you can reassemble your runs in no time.
Old 10-21-2013, 12:23 AM   #11
Does it make sense to lay tile before setting the tub? Or set the tub then lay tile? Also I have plywood subfloor, what type of subfloor should I go back with?
Old 10-21-2013, 08:41 AM   #12
Gymschu's Avatar
Rewards Points: 246
You have to set the tub first & you will need something better than plywood to lay tile. Cement board or something more compatible with tile. Plywood will simply crumble with the addition of thin set when you go to lay the tile. I'm not an expert in tile so hopefully someone adds more info to the discussion to give you a better idea of what you are up against.
Old 10-21-2013, 09:29 AM   #13
Yeah I was going to go with some durock or something. Just wondering what people are going with these days for subfloor replacements in bathrooms. I had the tub replaced a year ago and its caving thru the subfloor on the drain side. I'm also being told in going to have to set the tub mortar
Bath Remodel & Ideas Needed - Noob Alert Fittest Kitchen & Bath Remodeling 3 08-01-2014 12:21 AM
Basement bathroom shower remodel NewHomeDIYGuy Kitchen & Bath Remodeling 39 11-26-2013 11:20 AM
4.5 ft x 9 ft bathroom remodel = HELP! xcntryskiing Kitchen & Bath Remodeling 8 09-26-2012 02:17 PM
Newbie with bathroom remodel pierrekitty Remodeling 20 03-10-2011 05:22 AM
Need ideas and advice for small bathroom remodel nicet4 Plumbing 3 10-18-2010 11:46 AM
