Bathroom Remodel Advice- Shower - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-12-2013, 03:27 PM   #1
bathroom remodel advice- shower
Hello, I am planning on updating my bathroom, Im sure I will be posting some more questions down the track, the house is on a slab, single level,
I want a walk in, completely barrier free shower with a glass panel (900mm wide) on one side and a linear drain, somthing like this -
I will be putting in some premade floor slopes to the drain, my qu is, since im not having a glass panel opposite the shower head, will water splash further than the drain? It is 1500mm long.
Thank you for any replies.
breakerboy2000 is offline   Reply With Quote
Old 09-14-2013, 08:50 PM   #2
Rewards Points: 454
I have no idea what 1500mm is but why would you not have glass around the shower and i cant really tell where your drain is on the picture.
scottktmrider is offline   Reply With Quote
Old 09-14-2013, 11:38 PM   #3
Hello thank you for your reply, we think it would be nicer with only one panel of glass, but if need be we can put another smaller one at the base,
the linear drain is represented by that long rectactagle along the wall,
1500 millimeters, as in 5 feet.
thank you.
Old 09-15-2013, 07:51 AM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
1500mm is just short of 5'.
It will more than likely get wet past that point. How wet will also depend on your showerhead.
Old 09-15-2013, 07:10 PM   #5
Rewards Points: 960
I would go with it and adjust the shower head as necessary if you get water out past 5'.
You can slope the area out past 5' as well.
What are your plans for waterproofing the slab and what are your plans for placing the slab?
cleveman is offline   Reply With Quote
Old 09-15-2013, 11:00 PM   #6
Rewards Points: 258
and your shower users
redman88 is offline   Reply With Quote
Old 09-16-2013, 11:21 AM   #7
Stuck in the 70's
Our shower is approx 3' x 4'. After I shower there is often shampoo suds fairly high up on the wall. If there wasn't a wall there I'm sure it would be past the five foot mark.
I don't think you would have a flood out that far, but I would expect some shower spray, and if you have any kind of slick floor, safety could be an issue.
Tricky bathroom remodel - any suggestions? mannewskie Remodeling 8 04-03-2013 06:26 PM
The Bathroom Remodel that just kept growing... gpsmith Kitchen & Bath Remodeling 1 05-28-2011 05:25 PM
I do fire sprinklers but joined because I need bathroom remodel advice nicet4 Introductions 1 10-17-2010 01:42 PM
Double Bathroom Remodel coreyandnicole Kitchen & Bath Remodeling 1 03-19-2010 09:59 PM
Bathroom remodel / need advice on plumbing teamcanada1 Plumbing 2 03-07-2010 12:50 PM
