Bathroom HELP - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-23-2011, 12:02 AM   #1
bathroom HELP
help and info..bathroom remodel for the floor.. i have old 1/2 plywood so i installed 5/8 lp tophotch 450 osb to the floor over the 1/2 would that be ok?and would like to install schluter underlayment ditra 5m ontop of the lp so i can install some stone tile would this setup be ok?and could i put the schluter under the tub?
maxx is offline   Reply With Quote
Old 04-23-2011, 08:00 AM   #2
Rewards Points: 5,336
Stone tile on the floor requires a very rigid substructure. More so then ceramic tile. I have no idea what, "5/8 lp tophotch 450" is. The 1/2" ply is inadequate as a subfloor. Whether you can put stone down depends on the joist system size, spacing and span, as well as the proper subfloor setup.
To make your posts more readable it would help if you traditional English and not a texting format.
Ron
Old 04-24-2011, 07:55 PM   #3
sorry about the format,new the chatrooms.the "5/8 lp tophotch is a osb plywood.so what do you think about it all..just looking for some input
Old 04-24-2011, 10:39 PM   #4
Do you mean 5/8" LP Top Notch OSB?
Ron
Old 04-24-2011, 11:47 PM   #5
yes i do.
Old 05-04-2011, 08:09 PM   #6
would that floor setup be ok to install??
Old 05-06-2011, 02:43 AM   #7
any help
Old 05-06-2011, 07:06 AM   #8
DIY staff
Rewards Points: 7,174
We need the joist span--joist size---species ---and spacing---The OSB was a poor choice for natural stone---Not very strong---The Amazing John Bridge Forums Deflect-O-Lator :-)
Get back with useful data--Mike---
maxx (05-18-2011)
Old 05-06-2011, 07:28 AM   #9
any help
It would help if you answered the questions asked of you. I asked you about the floors substructure on 4/23.
Still no response except, "any help" .
This dialogue doesn't work in a vacuum.
Ron
Old 05-06-2011, 06:52 PM   #10
floor is 2*10's 16"on center with 1/2 plywood then 5/8 lp tophotch 450 osb on the top of it all
Old 05-06-2011, 08:46 PM   #11
How far do the 2x10's span, unsupported under the floor?
Ron
Old 05-07-2011, 12:09 PM   #12
span is 10 feet and they sit on steel i-beem's one on each end that's are 5"by8"
Old 05-07-2011, 01:39 PM   #13
Check a deflection table with the components you have and see if it's up to the task of a stone floor. The John Bridges forum might have one.
Ron
Old 05-09-2011, 10:39 AM   #14
Ron
thanks but i don't know what to do with that i did look at it but let me tell you i have no clue what to look for
Old 05-09-2011, 01:29 PM   #15
Without knowing your deflection rate, you're just guessing. It could be an expensive lesson if you guess incorrectly.
Ron
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 09:00 AM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
gutting bathroom debiasio Remodeling 30 02-17-2011 02:32 PM
Bathroom fan replacement reveals...a mess merlanvp Electrical 0 07-25-2010 08:00 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
