Bathroom Floor Repair - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-23-2008, 03:20 PM   #1
Bathroom floor repair
Old toilet leaks have rotted flooring around toilet. I have inspected from crawl space and damage does not appear to migrate under the tub. I plan to remove a small vanity w/ sink and the toilet to make the flooring repair. I want to leave the tub/shower where they are and work only on the exposed flooring. I also wish to replace the linoleum w/ tiles. I'm sure there have been posts on these subjects in the past and I would appreciate any words of wisdom that I could get before starting this project. Thanks in advance for your help and suggestions.
Mike
mik1947 is offline   Reply With Quote
Old 11-23-2008, 10:14 PM   #2
Aside form your tub, I would replace the entire sub-floor for you tiles, not just the rotted parts. Give you new tile floor a strong flat surface. It might be possible to cover the old subfloor with your new one. As long as adding the height won't effect anything major.
monkeywrench is offline   Reply With Quote
Old 12-07-2008, 05:47 PM   #3
Thumbs up
Thanks, monkeywrench! I plan to do just that! I'm going to remove everything but the tub and replace the whole subfloor that is exposed. I will also be working to get the subfloor to a height that will allow me to put down the new tile and keep the same finished height as the present floor.
Old 12-08-2008, 10:00 AM   #4
Long-Time DIYer
Mike Swearingen's Avatar
Mike,
It isn't discussed, but I assume that you know to put the tiles on cement backerboard and not directly onto wood, such as plywood, or the grout and tiles can crack.
Mike
Mike Swearingen is offline   Reply With Quote
Old 12-08-2008, 11:22 AM   #5
Thanks, Mike. I was not aware of that. Does the backerboard come in the same thickness as subfloor plywood?
Old 12-10-2008, 01:07 PM   #6
Drywall contractor
Rewards Points: 1,070
Backerboard comes in 1/4" and 1/2". Generally 1/4" is used on floors and 1/2" is used on walls. Check the mfgr's. specs for the tile you are going to use. They are usually pretty specific as to the the types of subfloor, underlayment, types of thinset, etc. for their product. Failure to follow their guidelines will void your warranty. You may want to post on the flooring forum for more help....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 11:04 AM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 10:10 AM
