Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-10-2011, 11:58 PM   #1
Bathroom floor not flat!!!
So I've completed the bathtub tile surround (Wife was really happy) but I have stalled on tiling the bathroom floor (wife is not very happy). The floor has a considerable crown down the center.
The floor is level to the left but it just dives off.
This carries right to the doorway.
My question is what product would you recommend to level the floor for installing 12X12 ceramic tiles.
I am removing the linoleum and will clean adhesive the best I can. Also the hallway beyond the doorway will eventually be carpet.
DimeBag1976 is offline   Reply With Quote
Old 12-11-2011, 12:19 AM   #2
Tileguy
Bud Cline's Avatar
Self Levelling Compound is the way to fix that problem.
Old 12-11-2011, 01:06 AM   #3
Disabled wood vet
titanoman's Avatar
I can't tell if that's concrete or wood. Wood can be flattened out pretty easily.
titanoman is offline   Reply With Quote
Old 12-11-2011, 01:47 AM   #4
If I was to use self leveling compound, Bud, would I build a little form along the doorway threshold edge to keep the liquid inside the doorway and level? Is that proper? The subfloor is 1/2" above the regular 3/4" T&G sheathing.
Old 12-11-2011, 01:49 AM   #5
Here's a better angle.
Old 12-11-2011, 05:48 AM   #6
Super Moderator
You will need a backer board or a membrane--to ensure the best bonding of the tile---
With a concrete backer----set the 1/4" backer into a bed of fresh thin set and nail or screw it down---then add the self leveler---
If you are adding a membrane instead--like the Schluter or Noble membranes--the leveler is applied to the subfloor before the membrane is installed.
Old 12-11-2011, 10:41 AM   #7
Just be aware that self-levelling compound is pretty expensive.
Old 12-11-2011, 01:30 PM   #8
Tileguy
Bud Cline's Avatar
Cost is relative to the alternatives available. In this case I would say the SLC cost would be most cost effective.
http://www.diychatroom.com/blogs/ins...t-one-two-177/
Old 12-16-2011, 07:59 PM   #9
I'd be taking a look under the house to find out why it dropped that much in that short a distance. If there something wrong it needs to be fix or that tile floors just going to fail.
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 10:29 AM
Soundproofing a Bathroom jbitt Remodeling 8 01-29-2010 11:53 AM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 11:10 AM
