Bathroom Exhaust Fan - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-03-2013, 10:26 AM   #1
I'm looking to add an exhaust fan in my bathroom. Are there any codes that I should have to follow to where I should place the fan and the vent? I was thinking of venting on the roof but would like vent on the side of my house.
I live in maine, which I'm assuming would make a difference.
johnsorious is offline   Reply With Quote
Old 06-03-2013, 10:34 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,148
This is where it helps to have your location in your profile. In some areas, there are issues with 'cold' weather....something about that white stuff that can collect on roof...warm air from the vent melts it...turns to ice...keep repeating the cycle...pretty soon it's all blocked...
You need to check with your local building and safety on any local requirements....there is a max limit on how far.
In most cases, the manuf will have the details in their instructions. I think it's rare that they go contrary to code.
Try to avoid using the flexible plastic stuff that comes with most fans....I used 4" hard pipe. Hopefully some of the experts will chime in...I believe you can use PVC if you want.
One piece of advice....get a quiet one....most of them will list the noise on Sones. If you get one that is about 4 Sones or less...it won't drown out a conversation...
I connected mine to a occupancy sensor. The people in my house do NOT know how to turn off lights. Ours also has a light...
ddawg16 is online now   Reply With Quote
Old 06-03-2013, 10:41 AM   #3
I am located in Greene, me.
Old 06-03-2013, 11:02 AM   #4
JOATMON
ddawg16's Avatar
Yea...you get the white stuff.....the only time I see it is on TV.
If you don't mind...put that in your profile...ME would be enough...it's not like Maine is the size of Texas....though I must add, Maine is a very fine state...
Old 06-03-2013, 12:08 PM   #5
I'm leaning towards venting through the side of the house. Is there an advantage of venting through the roof versus the side?
Also can I find the local codes for venting online?
Old 06-03-2013, 04:39 PM   #6
Rewards Points: 3,130
As far as I'm concerned, venting through the roof is always the last option. Especially when you get snow - as little as three inches and your vent would be covered. And in cold climates, vented vapor can condense in the piping and drip back into the bathroom. Further, any hole in your roof CAN leak; through exterior walls, hardly ever.
I agree that ME is a fine state. I lived there for a few years (Wiscassett/Boothbay Harbor area) back in the 1970s when the Maine Yankee nuclear plant was operating.
Old 06-03-2013, 05:41 PM   #7
GBrackins's Avatar
Rewards Points: 2,108
Maine Building Codes can be found here http://www.maine.gov/dps/bbcs/
normally such things as a bathroom exhaust fan would fall under manufacturer's specifications and recommendation not the actual code. codes require that mechanical systems be installed per the manufacturer instructions.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 06-24-2013, 06:12 PM   #8
If you vent out the wall, try not to do so under a ventilated soffit, or you may just pull some of that moist air back into your attic.
pkovo is offline   Reply With Quote
Can I put my bathroom exhaust fan outlet where I want to? danielrg HVAC 9 04-07-2013 08:44 AM
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 11:36 AM
adding can lighting and bathroom exhaust fan to aluminum wired house matjam68 Electrical 2 03-22-2010 11:50 AM
Basement bathroom exhaust fan install krusty HVAC 5 09-15-2009 08:41 PM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 08:59 AM
