Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-29-2008, 11:21 AM   #1
bath remo
I am thinking about remodeling my bathroom a bit.
  • Move the walls towards bedroom (which is huge)
  • demolish the wall that parts sinks with the rest of the bathroom
  • install triangle bathtub (jacucci like) I am not sure if it will fit…
  • put tiles and tops and elevate the top a little bit
http://i282.photobucket.com/albums/kk267/chilangopolaco/IMG_1628.jpg
http://i282.photobucket.com/albums/kk267/chilangopolaco/IMG_1629.jpg
http://i282.photobucket.com/albums/kk267/chilangopolaco/IMG_1630.jpg
http://i282.photobucket.com/albums/kk267/chilangopolaco/IMG_1631.jpg
project #3
http://i282.photobucket.com/albums/kk267/chilangopolaco/IMG_1632.jpg
http://i282.photobucket.com/albums/kk267/chilangopolaco/IMG_1633.jpg
My questions are around 1 and 2. Would it be a good idea to increase the size of the bathroom at the expense of the bedroom? As I mentioned the bedroom is big … the closet would be bigger as well. The wall would run close to the window though…
Also what is more contemporary. ? opened bathroom and sink area or I would rather keep the tub area separate from the sink area ?
The whole area would be close with some pocket door. I welcome your comments and suggestions – thanks!
chilangopolaco is offline   Reply With Quote
Old 04-30-2008, 11:09 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
bath remo
I would not move that wall out. You have the window in the bedroom that you're messing with by moving the wall.
Also, by moving the tub, you may also have to move the plumbing (drain). Do you have the cost of (possibly) moving plumbing around in your budget?
Finally, I tell home owners that are considering major remodeling projects to also get the advice of a local realtor. If a realtor says it would be beneficial, that's a big thumbs up however, if they tell you it's not going to give you any return on investment OR actually hurt the homes value, well then you have your answer.
angus242 is offline   Reply With Quote
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 01:09 AM
Bath Box drainage all gone bad. HELP shwingirl Plumbing 14 01-03-2008 05:25 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 03:52 PM
Unidentifiable pipe/vent in bath Hobiedog Plumbing 1 12-02-2005 06:33 PM
