Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-04-2008, 07:44 PM   #1
Basment Slider header Opening
Can I replace a basement door header for a slider, This will be a 6ft wide door, current header is 2 2x10's and I need a few inches. Can I replace with 2 2x6's and be good to go. above door is main floor and roof?
rayst is offline   Reply With Quote
Old 05-04-2008, 08:37 PM   #2
I have gas!
Clutchcargo's Avatar
Probably not.
Let me get this straight, you have a wider and taller opening than what is there?
You may be able to get away with 7 1/4 MicroLam. Check your local lumberyard and have them size the header. This service is free at many lumberyards if you buy your stock there.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Basement Slider Header rayst Carpentry 3 05-05-2008 10:22 AM
Garage Header Insight red3908v Building & Construction 4 04-27-2008 09:55 AM
Header size for wall opening firebirdbd Building & Construction 1 08-07-2007 06:11 PM
Framing Opening Length captainron19 Carpentry 3 04-01-2006 11:50 AM
Moving Header Supports Star Building & Construction 3 09-25-2005 01:50 AM
