Basement Window Formed In Foundation. - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-11-2010, 09:11 PM   #1
Rewards Points: 150
Basement window formed in foundation.
Need three new windows in basement. They ere formed in foundation. Do I cut them out of concrete or remove window sash and box around.
ianc435 is offline   Reply With Quote
Old 11-12-2010, 07:02 AM   #2
If the frames are in good condition, I use the old frames as stops for new vinyl windows. Order the windows slightly less than the concrete opening, apply caulk around the old frame and stick the new windows to the frame. Tnen use tapcons thru the sides into the walls. Foam around for airtight seal.
Old 11-12-2010, 07:08 AM   #3
Rewards Points: 150
Never though about using frames as a flange, good idea. They are in pretty good shape. I could scrape a spray a coat of metal paint on frames. Bosdy shops use rust primer, turns rust into aprimer ready to accept paint.
Old 11-12-2010, 09:41 PM   #4
Concrete & Masonry
Rewards Points: 530
I've put alot of cast-in place steel window bucks in place through the years when pouring foundations, and I wouldn't attempt to take them out unless you were desperate. There as tough as nails. There are a ton of decent windows available that "should" simply clip into your current steel frame in a matter of minutes. The hard part will be locating a local supplier.
jomama45 is online now   Reply With Quote
Increasing basement window size FirefighterGW Building & Construction 6 08-31-2010 09:49 AM
Framing and Trimming Basement Window mjkpainting Carpentry 2 06-28-2009 10:33 AM
Basement Window Replacement MikeyL Building & Construction 1 05-27-2009 07:08 PM
Painting Basement Floor and Foundation Walls meth Painting 5 09-26-2008 08:54 AM
basement window replacement ponch37300 Building & Construction 3 08-12-2008 04:58 PM
