Basement Waterproofing Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-14-2012, 05:41 PM   #1
Basement waterproofing question
Hi there,
First post in these forums, so apologies if this has already been covered. However I'm completely torn between options for waterproofing my basement and I could really use some advice.
Our basement sometimes has a small amount of water coming through the floor, and sometimes the fieldstone is damp with condensation. I understand that the latter is quite frequent as the stone tends to sweat. (We also used to have some moisture at the corners, but this disappeared after I installed downspouts correctly.)
We want to finish the basement and have had quotations for two systems - an interior perimeter drain with a sump pump, and an epoxy-type sealing. The sealing process is much more expensive and frankly the service has poor reviews, but the basement remodeling contractor is in favor of it.
I understand that with the perimeter drain system that water still enters the basement, but I don't understand why this should be a problem if the insulation has a vapor barrier. I'm also doubtful that a "lifetime" guarantee with a sealant can really be enforced.
Does anyone have any suggestions as to which is best, or are they both acceptable as long as they are done properly?
Thanks in advance!
ebuckley002 is offline   Reply With Quote
Old 12-17-2012, 04:51 PM   #2
Special User
Rewards Points: 1,230
I would not trust the sealant. Foundations only have to move a little bit with frost heave, the sealant cracks, and now you have no seal.
It's really, really hard to keep water out of a basement. Easiest thing to do is go ahead and let it come in, use vapor barrier to control it, and let the perimeter drain and sump pump take care of it.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-17-2012, 05:13 PM   #3
concretemasonry's Avatar
Rewards Points: 2,608
Sealing the walls will do nothing to prevent the water coming in through the floor. It is just a band-aid.
A perimeter drain removes the water around the home AND reduces the hydrostatic pressure that forces water to find a leakage point somewhere into the living space.
Dick
concretemasonry is online now   Reply With Quote
Question on basement wall/foundation height iub98 Building & Construction 6 07-15-2012 10:15 PM
Unique basement insulation question gunner74 Building & Construction 2 12-08-2011 08:45 AM
Basement sloping and subfloor install - question globus999 Building & Construction 2 06-17-2010 01:17 PM
Running Wires From Basement Question reb162 Electrical 5 06-11-2010 04:08 PM
Basement Insulation question tophercole Building & Construction 0 11-19-2009 09:01 AM
