Basement Waterproof Paint - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 01:16 PM   #1
Basement waterproof paint
Iím getting ready to finish my basement and I want to avoid (as much as possible) any future mold issues. Iím planning to apply 2Ē of closed cell foam between the wall studs and the cement but I was wondering if itís worth the cost to apply a waterproof paint to the cement prior to foaming?
I realize that cement is always wet but I have no visible leakage.
bfackrell is offline   Reply With Quote
Old 01-25-2012, 02:42 PM   #2
Registered User
Rewards Points: 4,924
The wet evaporates as soon as it forms.
No dryloc unless you have a interior drain system; http://www.buildingscience.com/docum...lation-systems
Gary
Old 01-25-2012, 09:01 PM   #3
Rewards Points: 4,454
2Ē closed cell foam will be very efficient insulating the wall from the earth's 68*f ambient temp,,, there is NO waterproof paint,,, there are some coatings that will be suitable for tank coatings however your issue would be the reverse - exterior water would still penetrate the wall to the coating & then lift off the paint,,, better you should coat the walls w/either kryton OR xypex & leave the stuff on the shelves at the apron/vest store,,, yes, it IS worth the cost/effort but nothing will work if its 1/2 ass'd which path you've already begun,,, a properly constructed concrete bsmt wall is never ' always wet '
any visible leakage can take years to show itself yet, in the meantime, damage is occurring unbeknownst to anyone
Old 01-26-2012, 01:10 PM   #4
Why wouldn't the same happen to one of the products that you mention: kryton OR xypex
Any idea what the cost is? I can't find pricing without calling a rep.
I guess what I meant to say is that concrete always has water in it...right??
Old 01-26-2012, 01:16 PM   #5
Rewards Points: 1,092
I don't think so. It does take time for slabs and blocks to dry, but they don't have infinite water in them. Concrete is porous, and water will move through it. If you don't have water penetrating from the outside, and you don't have excessive humidity hitting cold blocks, you should not have "wet" blocks. Do a search here; many threads on this topic.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Painting Old House Smokin Gun Painting 36 07-05-2011 02:24 AM
Waterproof paint on block walls koolie Painting 9 03-23-2011 07:50 PM
Best Paint for Basement Walls and Floor? Vikeologist Painting 5 11-30-2009 07:03 AM
Advice on basement waterproof paint shaan71 Painting 4 04-24-2009 06:58 AM
