Basement Walls Renovation Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 05:34 AM   #1
basement walls Renovation question
Hello!
I'm currently finishing my basement. I install 2 inch xps on the walls and 1 inch on the floor. I'm installing plywood on the floor today and then studding out the walls after that. The walls are going to be built on top of the plywood because they aren't going to be load bearing in any way... Just a ring of walls against the xps to hold electricity and sheet rock.
Anyway, because the walls are going to be built on the subfloor is there any reason to use a treated board on the bottom? I don't think there is but figured it'd be worth asking.
Thanks!
Damon
Subliminal is offline   Reply With Quote
Old 06-15-2012, 07:45 AM   #2
Rewards Points: 6,652
It is really up to you.
Old 06-15-2012, 09:44 AM   #3
Rewards Points: 1,476
If there is ever a flood then it could be nice to have. Keep in mind the flood could be from rainfall or from a burst pipe somewhere in the house.
mikegp is offline   Reply With Quote
Old 06-15-2012, 10:20 AM   #4
Local code here requires that any wood in contact with concete be treated wood or have a barrier between the two. Moisture will wick through concrete. I have stripped out 30lb felt and stapled it to the contact side of KD lumber, but the sleepers were installed to allow air to move from the floor bays into a continuous space behind the outside stud wall and then open to the joist bays above so that it could breathe. It was also an older home with no history of any moisture problems in the basement. Suggest you check your local code and remember, building codes are a minimal standard.
wdwrkr30y is offline   Reply With Quote
Old 06-15-2012, 10:28 AM   #5
There will be no contract with the concrete. 1 inch xps then 3/4ply then bottom plate of wall.
question about finishing basement walls / framing indianboy08 Carpentry 3 12-05-2011 05:23 AM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 12:07 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 02:43 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
