Basement Wall Framing. - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-12-2012, 07:53 PM   #1
Rewards Points: 77
Basement wall framing.
Hey folks,
Quick question. If a part of my un-framed basement wall is say 10', do I build an 8' and a 2' or 5' and 5' or 6' and 4' wall? Might seem like a silly question but hey, i'm a newbie to carpentry.
mlijoi is offline   Reply With Quote
Old 11-12-2012, 07:58 PM   #2
Rewards Points: 14,290
Odd question.
Why not just build a 10' wall?
2 X 4's come in at least 6 differant standard lengths, 10' being one of them.
Old 11-12-2012, 08:08 PM   #3
Rewards Points: 6,652
Depends on what you are building the room for. If doing a home theater, you want as much head room you can get, so that you do not hit your head, when standing up on the platform, that your second row of seating is on. Also with the higher ceiling, it gives you some play if you on the other hand, you wish to lower the ceiling in a room to say 8 feet, vs. having it at ten feet. That would allow you to also make the room quiet, since it would not be connected to the floor joists for the rooms above it.
Old 11-12-2012, 08:11 PM   #4
Rewards Points: 77
Gents,
All the 2x4 are 8' as I got them for a really good price. And by 10' I mean length, not height.
Old 11-12-2012, 08:17 PM   #5
Rewards Points: 29
Baseplate on cement should be treated lumber, not regular pine.
Lay down an 8' baseplate then the remainder, same with the top plate, then run your studs every 16" oc.
MarkusAIC is offline   Reply With Quote
Old 11-12-2012, 08:18 PM   #6
Then even if they were free you just made it twice as hard to build, added a ton of cuts, and harder to keep the wall flat and not flex.
Old 11-12-2012, 08:20 PM   #7
Originally Posted by mlijoi View Post
Gents,
They only have a height when you stand them on end.
Old 11-12-2012, 08:22 PM   #8
Rewards Points: 77
I will be covering base plate with tar paper. Do I not build the wall on the floor and stand it up?
Old 11-12-2012, 08:24 PM   #9
Framing Contractor
Rewards Points: 126
The tar paper is not the right way.
Sometimes we build the walls in place and sometimes we pre build and stand.
sixeightten is offline   Reply With Quote
Old 11-12-2012, 08:39 PM   #10
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,326
for the bottom plate use either sil gasket of 6 mil poly not tar paper
woodworkbykirk is offline   Reply With Quote
Old 11-12-2012, 08:44 PM   #11
Rewards Points: 77
Why's the tar paper such a bad idea?
Old 11-12-2012, 08:53 PM   #12
It soaks up moisture after time, plus dries out when it gets old.
The Following User Says Thank You to gregzoll For This Useful Post:
mae-ling (11-13-2012)
Old 11-12-2012, 08:54 PM   #13
Rewards Points: 77
Ok, poly it is!
Old 11-12-2012, 08:58 PM   #14
AHH, SPANS!!!
Rewards Points: 1,166
you will not be able to build the wall and stand it because it will bind against the floor joists, unless you build the wall a little bit below the floor joists and shim it after it is stood up. Also , a pressure treated bottom plate is but a trip down the road to the lumber store...
hand drive is offline   Reply With Quote
Old 11-12-2012, 09:05 PM   #15
Rewards Points: 77
Ok, if I decide to stick frame, how do I get the same distance from the foundation on the top plate and the sill plate so that the studs are plum? I've always wondered that.
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
condensation behind vapor barrier of walkout basement wall fusion_ta66 Remodeling 10 08-01-2012 10:14 PM
Framing Basement Wall Underneath Beam Micker Remodeling 5 07-31-2012 08:37 PM
Framing basement exterior walls gheffron Building & Construction 7 06-08-2012 01:00 AM
Framing new wall in basement civil_corruption Carpentry 2 02-12-2007 07:23 AM
