Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-12-2008, 09:05 PM   #1
Basement vapor barrier question
I'm finishing a basement and have a question about the vapor barrier. The walls in this section are half foundation and half studs/siding with insulation and vapor barrier. I'm building a full wall in front of this. I saw in a previous post the need to remove the old vapor barrier to avoid trapping moisture between the old one and my new one. My question is since there's a gap between my top plate and the original top plate, do I need to do anything with my vapor barrier when i reach my top plate to seal back to the original top plate. My question is mainly about the wall that runs perpendicular to the joists, but there will be a similar question on the adjacent wall that runs parallel to them. I'm in Kansas if that matters from a climate perspective.
rob7young is offline   Reply With Quote
Old 04-12-2008, 10:30 PM   #2
ICF Construction
Insulation and vapour barrier need to run all the way into the joist cavity and touch the bottom of the subfloor to meet 'code'.
Chris
Chris Johnson is offline   Reply With Quote
Old 04-13-2008, 10:10 AM   #3
Yup, and fill the space between the 2 stud walls with insulation. Rib batts apart and lay them in horizontally for the best coverage.
Gencon is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-23-2006 12:03 AM
Bathroom in Basement Question MudDuck Plumbing 5 09-14-2005 09:07 AM
