Basement Steps - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-27-2012, 10:26 AM   #1
basement steps
What kind of hand railings do you need on open basement steps. One side or two sides etc etc?
silkscreener is offline   Reply With Quote
Old 02-27-2012, 10:41 AM   #2
You need to check with the building inspector in your area to know for sure. When I was doing finish carpentry, the contractor made me install a 2 x 6 on each side of the stairs at the bottom, screwed into the side of the stair stringers and extending up to the floor joists of the 1st floor, where they were also screwed in. Then, 2 x 6's were angle cut to the angle of the stairs (39-40*), and attached to the under side of the 1st floor joists at the edge of the stair well and down to the vertical 2 x 6 at the bottom of the stairs. These 2 x 6's were 5" apart. The top one served as an attaching surface for handrail brackets and a wood handrail. That filled the requirements for that area.
MNsawyergp is offline   Reply With Quote
Old 02-27-2012, 10:44 AM   #3
Rewards Points: 13,472
Same rules as any inside hand railing.
http://inspectapedia.com/interiors/Stair_Railings.htm
basement steps silkscreener Remodeling 1 02-25-2012 03:19 PM
what's the consequences of a well insulated basement diy001 Building & Construction 1 06-12-2011 01:13 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 07:46 PM
Sunlight for a Basement Room prglor Remodeling 1 08-31-2008 04:29 PM
