Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-23-2011, 02:35 PM   #1
basement stairs
I am trying open up my stairway going down to the basement. I have already cut the opening at the bottom I am just having trouble trying to plan for the railing that I will need to put up. I am having trouble figuring out how to plan. It's not very thick up to the existing wall and is all open. The picture attached is before I cut out wall. That part is down now
wilkbra1 is offline   Reply With Quote
Old 02-24-2011, 09:31 AM   #2
basement stairs
Post a picture of the current condition. You would plan the railing based on the situation you have now.
Ron
Old 02-24-2011, 05:06 PM   #3
basement stairs
Hope this helps
Old 02-24-2011, 05:18 PM   #4
basement stairs
Originally Posted by wilkbra1 View Post
Hope this helps
Not even close.
Will the staircase be with open or closed stringers?
What will the balusters rest on?
If any of this terminology is not familiar, look up, "stairs and hand rails" to see what each detail looks like , then post a picture of the one you want to do.
Ron
Old 02-25-2011, 07:31 AM   #5
basement stairs
Basic stair rail components: newal post at the bottom, rail from that up to some terminating surfare or another newal post, balusters(vertical or aligned with rail) or something to keep kids from falling thru, and support the rail.
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
Cutting drywall side of basement stairs? Oxymoron Drywall & Plaster 4 10-07-2010 10:13 PM
Basement Stairs. Bill0730 Building & Construction 1 08-16-2010 10:37 PM
Basement Stairs/ EZ Stairs mjkpainting Carpentry 8 02-24-2010 10:24 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
